Old 04-24-2012, 08:12 AM   #1
Spaz
Loose steering, floating
My truck is new to me an im still learning it. Now my question is, as im driving, and if i have to steer it takes at least 1/5-1/4 of a turn before the truck responds. It has a large what i can refer to as a floating area f its steering. The guy i bought it from said its the pitman arm. Is it the arm or is it the gearbox? Just curious. Thanx
Spaz is offline   Reply With Quote
Old 04-24-2012, 09:05 AM   #2
yuccales
yuccales's Avatar
Re: Loose steering, floating
That sounds like way to much free play to just be the pitman arm. If you look through the fender well and turn your steering wheel shaft back & forth, you can get an idea how much slop you have in your steering box.
yuccales is offline   Reply With Quote
Old 04-24-2012, 09:08 AM   #3
Spaz
Ok thanx. Is there a wAy to adjust the steering box or wil it need to be replaced?
Old 04-24-2012, 09:45 AM   #4
68gmsee
Active Member
68gmsee's Avatar
Most gear boxes -manual or power- have some adjustment you can tighten but be careful because if you have to adjust a lot of play it's usually worn enough to be dangerous.
First thing I do is to have someone (wife in my case) wiggle the steering wheel while I view the shaft going into the gearbox.
If it looks like there isn't any loose movent there I look under the front end and see if I can detect any movement there.
Next is to grab the tie rod ends and rotate them. If they move easily, they're worn.
Last, if I can't determine where the slack is, I bite the bullet and take it to a front end shop for a thorough exam. They have the expertise and special tools to check for wear.
Regardless of what action you take, I'd be very careful about driving it. Life is too short as it is...
68gmsee is offline   Reply With Quote
Old 04-24-2012, 10:24 AM   #5
Spaz
Awesome. Thanx for the info. Imma look at it myself first to see and leant the steering and suspension. Not much i know about it. But ill probably take itto a shop anyways. Thanx alot man.
Old 04-24-2012, 11:06 AM   #6
hayhauler71
hayhauler71's Avatar
stearing box or the rag joint could be shot
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-24-2012, 11:17 AM   #7
Spaz
Thanx hay!!
Old 04-24-2012, 10:22 PM   #8
Lee H
Lee H's Avatar
If the system is old or has not been maintained well there is probably wear in all the components. Have someone turn the wheel just a little as you watch all the joints. Any movement before the next joint moves is suspect. Just a small amount of looseness in all the joints adds up to a lot at the wheel.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-24-2012, 10:34 PM   #9
Spaz
Thanx lee. Will do pimpin'
Old 04-24-2012, 11:59 PM   #10
slikside
slikside's Avatar
subscribed
slikside is offline   Reply With Quote
Old 04-25-2012, 05:45 AM   #11
Sammy
Do not take for granted the power steering box isn't worn out. I was very lucky and had one fail driving into a parking spot. I over looked the box since it was working and appeared in fine shape. When they fail they can lock up. No advance warning. At 5 MPH in my case. No longer will I have confidence in something designed to last 20 years that I cannot see the internals. Especially something that critical in maintaining control of a truck.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 04-25-2012, 07:49 AM   #12
xman
I had the same problem on my 72 burb it turned out to be the pitman arm replaced it and all is good now
It was so bad that it actually came apart when I took it out
xman is offline   Reply With Quote
Old 04-25-2012, 08:04 AM   #13
Spaz
Is the pitman arm mounted up with a bushing of some sort or something??
Old 04-25-2012, 10:28 AM   #14
xman
the pitman arm is mounted to the steering gear box with a nut/lock washer and the it is connected to the center link via ball joint where you get all the play from when that joint wears out like mine did
If you need to replace the pitman arm make sure you have pitman puller to break loose from gear box and pickle fork to break loose from the center link
I just rented the pitman arm puller from local parts store I had a pickle fork already
Old 04-25-2012, 10:42 AM   #15
Spaz
Thanx. Woulda never thought of the puller lol
Old 04-25-2012, 04:20 PM   #16
70STOVEBOLT
70STOVEBOLT's Avatar
I would check the ball joints as well. I had a lot of play in the steering like you are describing and I replaced the pittman arm, idler arm, and tie rod adjusting sleeves and I still had quite a bit of play until I replaced the ball joints. Now it has very little play.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-25-2012, 04:51 PM   #17
57larry
you could rebuild the complete front end
57larry is offline   Reply With Quote
Old 07-12-2012, 07:37 PM   #18
shok
Found this thread while searching instead of just starting a new thread. On my 66 there is also a lot of play and I confirmed the play is in the box itself. Whats the procedure to adjust? Just turn in a screw until some resistance is felt?
shok is offline   Reply With Quote
Old 07-12-2012, 08:47 PM   #19
Lee H
Lee H's Avatar
You should start a new thread. The screw your talking about is really not an adjustment screw to account for wear. It's really a preload screw. Some folks use it for an adjustment and most experts say not to turn it more th an 1/4 turn to take out the slack. if 1/4 turn does not help it's time for a swap.
Old 07-13-2012, 09:15 AM   #20
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've also found that adjusting the preload screw will cause the box to wear quicker.It basically puts more preload on the internals cause more friction,so if you adjust it make sure to start saving pennies fr a new box.When the one I adjusted went it was a parking speed bump of a curb.I went from a couple inches of play to over half a rotation of the steering wheel in a couple of yards.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-13-2012, 12:38 PM   #21
shok
Yeh I'm thinking I will leave it alone, I'm only driving it very locally and as soon as I get some other bills out of the way I'll just get a rebuilt one, or if I locate a kit and instructions rebuild it myself.
Old 07-13-2012, 12:49 PM   #22
TheSeeker
This is something I have been wondering about as well, I have a manual gearbox and would like to know how difficult it is to rebuild one. If it is even cost effective to try over buying a new/rebuilt one. I need to pull the front end apart and rebuild it anyway, but the box is the only puzzling part for me right now.
TheSeeker is offline   Reply With Quote
Old 07-13-2012, 07:47 PM   #23
sboris
sboris's Avatar
Seen this a while back..
http://www.fourwheeler.com/techartic...ild/index.html
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
