Old 04-24-2012, 11:16 AM   #1
Chvyman1975
Chvyman1975's Avatar
Cab swap
I just found a 63 BBW cab with windows. My questions is will this cab mount on my 62 frame without major fab work?
Chvyman1975 is offline   Reply With Quote
Old 04-24-2012, 06:06 PM   #2
60_project
Re: Cab swap
depends on what you consider major. The cab mounts are in different locations as the frames are different widths. but I wouldn't call this major, you can either fab up new mounts on your frame to match the new cab, or move the mount points in the floor of the cab to match your frame.
60_project is offline   Reply With Quote
Old 04-24-2012, 09:52 PM   #3
Chvyman1975
Re: Cab swap
Thanks for your input. I think Im gonna go with option 2.
Old 04-25-2012, 01:00 AM   #4
55reasons
55reasons's Avatar
Re: Cab swap
There is always option 3!
http://phoenix.craigslist.org/evl/ptd/2919782485.html
55reasons is offline   Reply With Quote
Old 04-25-2012, 05:41 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Cab swap
not to hard, rear mounts mount to the same spot, will just have to drill new holes for the front mounts in the cab.
pic shows a 63 frame with bolt coming through a 60-62 mount (reverse of what you are doing)
the 63 cab front brace will be the same as the one in the pic, and still has the divot where the mount pad for the 60-62 frame mounted up.
Old 04-25-2012, 07:03 AM   #6
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Cab swap
Hydraulic clutch 62, 63 had the rods.
