Old 04-24-2012, 11:22 AM   #1
Spaz
Rear bagged suspension built ?
I was wondering if anyone can guide me alon on this. I want to do a simple bag set up on the rear. What i was wondering is there anyway i can leave my trailing arms and just add a longer external bar and mount my bag on it outside the frame as kinda like a 4 link? I am thinking of getting some hangers and mount them to the frame. Then get a bolt on lower bar from a company i found. Just wondering if this would work? Looking for something easy and quick to do.
Spaz is offline   Reply With Quote
Old 04-24-2012, 12:04 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Rear bagged suspension built ?
The easiest way for the rear is bags right where the springs went. A longer trac bar with some adjustment to recenter the rear at ride height and some shock relocators w/ shocks. You can run schrader valves on the rear to set the height and leave it until you add air management in the future...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-24-2012, 12:46 PM   #3
Spaz
If i leav the bags on the trailing arms and add a 2" drop blOck on the axle, will it lay my frame on the back end? Some of the photos i see dont lay out withtheset up like this. If so ill do it this way
Old 04-24-2012, 12:55 PM   #4
VA72C10
VA72C10
VA72C10's Avatar
Didn't see you mention laying frame....you will need a large notch (not c-notch) to lay frame in the rear that will require cutting the bed floor....and no, you can't do it with stock trailing arms....
check out some of the setups in the suspension forum. Moving your post there so you can get better responses too...
Old 04-24-2012, 01:24 PM   #5
Spaz
Thanx va im sorry i wasnt clearer. Ill try that. New to the forum and still learning how to use it.
