Old 04-24-2012, 12:00 PM   #1
SunSoaked
SunSoaked's Avatar
The long shaft?
Got the old bed of project chaos this weekend. Couple of things of interest:
1) I am assuming the PO added "overload" springs at some point. They look like addition leaf springs mounted on top of the leafs but dont have spring "eyes" on the ends. They are only connected buy the U-bolt. The ends appear to contact the bottom of the bed when the "normal" springs are fully compressed. Is this correct?
2) There are two separate driveshafts between the transfer case and rear diff, supported by a bearing in the middle. I'm thinking that when I add some lift (4"-6") AND add a ranger splitter (moving the t-case rearwards another 12inches), the pinion angle on the rear shaft is gonna be really high.
Why not just run a single large tube from the t-case to the diff? I see large diameter (4 in) shafts on lifted late model trucks all the time. I'm pretty sure they are one piece?
SunSoaked is offline   Reply With Quote
Old 04-24-2012, 08:12 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: The long shaft?
Yes
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 04-25-2012, 04:40 AM   #3
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: The long shaft?
If you add the range box and push everything back, you can probably eliminate the double shaft. I would talk to a driveline shop, or call Jesse at High Angle Driveline in Cali...
http://www.highangledriveline.com/
(530) 877-2875
Main shop Phone Number
Hours 8am to 5pm for orders
Monday thru Friday - Pacific std time
Rich
1972 K5 Blazer CST Click HERE
Old 04-25-2012, 05:37 AM   #4
jjzepplin
jjzepplin's Avatar
Re: The long shaft?
I ran a ORD 203/205 doubler and 700r4 in my blazer and it made the rear shaft very short with a high angle. I dropped the t-case mount 2" and ran a telescoping shaft with a cv joint on the t-case side with a flange and made everything 1-ton spicer u joint from Tom Woods in Utah. Quite bullet proof. Put at least 30,000 miles on it joints are still good.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
