Old 04-24-2012, 05:55 PM   #1
madcow75
madcow75's Avatar
Question steering shaft
Okay I want to upgrade my steering shaft and get rid of the rag joint with an xj steering shaft, but I am not sure which are compatable. I am looking for some tech info please, before I go to the wreckers looking. I have a 76 column. There is a break in years from 73-78 and 79-87. I no that earlier are splined and newer have a square shaft. I am looking for an xj shaft for my splined steering column. Which are compatable for a 73-78 steering column? Does anyone have some input on this or done this. I am sure someone has.
madcow75 is offline   Reply With Quote
Old 04-25-2012, 06:48 AM   #2
v30crewcab
v30crewcab's Avatar
Re: steering shaft
I'm not sure there is one compatable with the splined column. maybe swap your column as well, or at least the inner shaft?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-25-2012, 09:10 AM   #3
madcow75
madcow75's Avatar
Re: steering shaft
If I were to rplace the inner shaft to the square 79-87 style, what year XJ shafts will work then?
Old 04-25-2012, 09:57 PM   #4
v30crewcab
v30crewcab's Avatar
Re: steering shaft
around 89-99 probably.
71 longbed 5.3 4l80
Old 04-25-2012, 10:00 PM   #5
madcow75
madcow75's Avatar
Re: steering shaft
Thanks for a little info.Have you made the swap on a square before? Does anyone else have any info on the swap.
Old 04-25-2012, 10:06 PM   #6
v30crewcab
v30crewcab's Avatar
Re: steering shaft
I have one on my 88 crewcab. very easy to do.
71 longbed 5.3 4l80
Old 04-30-2012, 03:44 PM   #7
puppy
puppy's Avatar
Re: steering shaft
Just cut the rag joint off and weld on a steeting u-joint. Borgeson makes a 1" bore that will slide onto the orignial shaft with a little material removal.
'11 Z71
'88 V-30 Crew Cab
'87 V-10
'69 Camaro SS
'52 M38
'46 Rat Rod
Word of the wise should be sufficient!
puppy is offline   Reply With Quote
