Rear end noise, can't figure it out!
I have an 87 K5 I don't drive often. I drove it today and heard a noise coming from the back of the blazer, I thought it was the parking brake rubbing so I took off both dorms, cleaned the brakes and backed off the parking brake adjuster, noise still there. Next I jacked the rear end and spun the tires manually and can clearly hear a soft dull thud sound that increases with speed. I had a friend push the brakes to see if the sound would change, it didn't. I checked the u joints and they are good. I feel no vibrations, only sound. Any ideas what I should look for next? Any help diagnosing this would be greatly appreciated!
Posted via Mobile Device |
Re: Rear end noise, can't figure it out!
remove the rear wheels & brake drums. This will eliminate the brakes all together. See if noise still exists. If it doesnt, then the problem is in the brakes, or drums rubbing backplates. If the noise is still there, then remove the rear driveshaft and see if noise is still there. If it is not, double check the driveshaft and or transfer case. If it is still there then you will need to check diff internals such as axle bearings and ect.
#3 | |
If you have a gov lock diff. Stop driving it immediately. It will grenade and blow and lock up your rear wheels.
Pull your diff cover and check the insides Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#6 | |
18 Till I Die
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
I took the Cover off the differential and found three teeth missing from the pinion gear, the are clean breaks and luckily didn't fly into the diff! The rest of the gears look perfect, I can't find even a scratch on them. So I'm thinking I simply need to replace the pinion, assuming that's the correct name, it's the input gear attached to the yoke.
Where do I find a replacement? Is this a part available at a parts store or should I look at the junk yard? Any ideas what they cost? Will I need to do any kind of shimming? Any details will be greatly appreciated! Posted via Mobile Device |
#8 | |
![]() You'll need to replace the ring and pinion as a set (you can't replace just the pinion gear and not the ring gear too). It will need to be "set up"; it's not rocket science but if you don't know what you are doing it would be best to have someone else do it, or talk you through it. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
18 Till I Die
Now would be the time to Swap in a Auburn posi Cause the Gov-lock could crater and take your new ring gear with it. Yes its more money but in the long run it would be worth it. If you plan on keeping the truck for awhile I would definitely. FYI I had 2 teeth missing on mine and they took the spider gears out and made a mess.
#10 | |
#11 | |
Must be a West Virginia pinion... 3 teeth missing...... I'm glad to hear you found the problem.
#13 | |
![]() OP, also glad you found the problem.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
