Old 04-24-2012, 10:37 PM   #1
slinginrods
slinginrods's Avatar
drive shaft swap
any body know of any later model aluminum driveshafts that will swap into swb th350 equipped 81-87?i know the 700 r4 trans shares the same yoke as the th350.but the length is different.but i was wondering if a 90s model or even newer aluminum drive shaft would work in my 84 with a th350.
slinginrods is offline   Reply With Quote
Old 04-24-2012, 11:55 PM   #2
slinginrods
Re: drive shaft swap
ok how about the length of driveshaft for a th350 with a 6inch tail in a shortbed.any body?
Old 04-24-2012, 11:57 PM   #3
walkerscott
aerostar ford u joints 3-3130bf
walkerscott is offline   Reply With Quote
Old 04-25-2012, 12:17 AM   #4
slinginrods
aerostar driveshaft fits?th350 short tail in a swb?
Old 04-25-2012, 09:39 AM   #5
walkerscott
i will measure and provide you dimension
Old 04-25-2012, 09:20 PM   #6
walkerscott
55.75 center cup to center cup
trans yokes come in 3 lengths and are listed shortest to longest center line to machined surface
power glide
th350
700r4-4l60e
there is almost 2" difference
Old 04-25-2012, 09:29 PM   #7
slinginrods
so let me get this right,you have a aerostar driveshaft in your truck?if so what year and how did you get the yoke from the ford to work in your th350?or did you just use the shaft and with a conversion joint you used the gm trans yoke.sorry im a lil confused
Old 04-25-2012, 10:10 PM   #8
walkerscott
gm yoke 10bolt 8.5 yes conversion joint 3-3130BF autozone advanced auto etc
