Old 04-25-2012, 10:33 AM   #1
senrabdl
72 chevy fuel gauge problem
I have a 72 chevy k20 4x4.
The fuel gauge stopped working one day so I replaced the sending unit, that did not fix the problem so I replaced the fuel gauge itself, still not working, I replaced these with new ones from LMC truck.
Any suggestions. Thanks for your help
Larry
senrabdl is offline   Reply With Quote
Old 04-25-2012, 07:42 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 72 chevy fuel gauge problem
Larry
It kind of depends on what you mean by not working... The needle doesn't move at all, or it fluctuates, or goes over past full. Stock tank? More info would help a lot. The wires are known to short out under the drivers side door sill or come unplugged from the fuse box or maybe a blown fuse. You will be looking for a 16ga brown wire... let us know.
LockDoc
Leon
Old 04-25-2012, 08:37 PM   #3
Coley
Coley's Avatar
Smile Re: 72 chevy fuel gauge problem
Quick questions:
Do you have dual fuel tanks?
Do you have a electric/toggle switch for them under/around the dash?
If so, try the switch in the other position.
(noting that it is a K20...3/4 ton)
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 04-25-2012, 09:20 PM   #4
senrabdl
Only one tank and it is stock,the gauge is pointing about at the 9:00 postion and then goes up to empty when the key is turned on and the tank is full. I will check for a short under the door sill tomorrow. The old gauge would go to full when I unplug the brown wire from the sending unit I have not tried that on this gauge yet.
Thanks for your help..
Old 04-25-2012, 10:25 PM   #5
Legolas894
Chemist under the hood...
Legolas894's Avatar
If you touch the sending unit wire to ground, the gauge will go to EMPTY. If it doesn't do that, the problem is somewhere before the sending unit. There's lots of posts on this if you search fuel gauge or something like that. If you take the sending unit out, you can check the resistance of it with a multimeter. They are usually 0-90 OHMs. As you move the float, check to see if the resistance is changing.
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 04-26-2012, 10:50 AM   #6
senrabdl
thanks for the suggestion I will check it out
