Old 04-25-2012, 12:58 PM   #1
Edahall
Window won't go down
I am getting ready to paint my Suburban and removed the wing vents. However, when I closed the door, the window switch got caught between the seats which caused the window to extend all the way up past where it would normally go. Now, I can't figure out how to get the window to go back down. It'll go down about 1/4" and just bind up. How do I get it to go back down?
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 04-25-2012, 01:54 PM   #2
chebyshortbox65
chebyshortbox65's Avatar
Re: Window won't go down
Unbolt the regulator and track from the door and slide it out of the track it works great I got a set of vent Windows out of a 90 sububan in the junkyard awhile back the Windows were up and no battery I did what I told you and had them out in 10 mins both sides
chebyshortbox65 is offline   Reply With Quote
Old 04-26-2012, 11:51 AM   #3
Edahall
So once I slide unbolt the regulator, I'll be able to slide the window off the track? Then how do I get the window to go back down? What's keeping the regulator from going down right now? I just want the window to go back down.
It's stuck all the way up and can't get it to retract.
Old 04-26-2012, 01:24 PM   #4
chebyshortbox65
It's Probly binding or the roller came out of the track once the glase is out the regulator should go back down
Old 04-26-2012, 09:26 PM   #5
Edahall
Once I removed the window, I was able to see that one of the arms got caught on the end of a bolt. Simply backing out the bolt freed the arm and I'm back in business.
