![]() Join Date: Aug 2008
WTB 3/8" fuel lines and air cleaner for 70 BBC truck
I bought a 70 Longhorn with a 400 BBC that was set up for propane with no fuel pump and I am swapping it to run on gasoline. The P.O. installed a Qjet and I have a stock in cab tank out of another truck, but I need the 3/8" fuel line that runs from the in cab tank to the fuel pump and the line that runs from the pump to the carb (Q-Jet). Inline Tube sells these for $60 and $20, so worse case I can get new ones for $80 + shipping, but figured I would try here first to see if I could save some $.
I am also looking for a stock air cleaner set up for the same truck. Let me know what you have including shipping to Leander Tx 78641 |
Re: WTB 3/8" fuel lines and air cleaner for 70 BBC truck
I purchased a air cleaner housing and riser yesterday from another member which should be arriving in the next few days. Last night going through some old parts guess what I found? Air Cleaner from one of my previous trucks(69 suburban). If this is what your looking for I am in Austin so would not have to ship. I didn't see the top but I didn't search too hard for it and if that's what your needing I can check.
Posted via Mobile Device |
If it is from a big block truck i am interested. Do you have an idea what you want for it? Do you have any photos?
It came off my quadrajet wasn't a bb though, not sure if the were the same. As long as the other one ordered comes in fine I have no need for it, yours if you want it no charge. It's in cedar creek where I'm doing my build and will be out there tomorrow. I can grab it and send pics then if need.
#5 | |
#6 | |
If it is from a big block truck i am interested. Do you have an idea what you want for it? Do you have any photos? |
Junior Member
you can get the tubing and fittings from Oriellys for $6 and all you have to do is bend it, the ends are all ready flared and fitting for the fuel pump and carb installed
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
I referring to the stock air cleaner set up at the end of your request not the lines.
Ttt
VA72C10
![]() Join Date: Mar 2008
I have a correct bb air cleaner with spark arrestor. 120 shipped.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
![]() Join Date: Jun 2005
#13 |
WIDESIDE72, I thought someone would describe the difference in the air cleaner of a BB and a SB, but must be a secret only know to a few good men! I'll go out on a limb and say there isn't anything different other than the spark arrestor, the downdraft tube and the manifold heat shroud, between them. Just sold a very nice one at the Charlotte Auto Fair.
Hope someone can help with this question! Thanks, Dan |
#14 | |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#15 |
VA72C10
I don't have a small block one right now so I couldn't compare and honestly never thought to before...makes sense that they're similar though...
#16 |
Ttt
