Old 04-25-2012, 03:33 PM   #1
dgreen
Does any one have this?
Just what it says, http://www.performanceonline.com/197...-KIT-FRK7387P/
If so pros cons , looking to over hall my Suspension. and also sell Tubular Control Arm for 80-87?
dgreen is offline   Reply With Quote
Old 04-25-2012, 08:15 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Does any one have this?
Pros: cheap.
Cons: no control arm bushing outer sleeve.
Cheap. Not name brand parts.
I'm song a full suspension rebuild on mine
With this kit you should also get the idler arm an pitman arm
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-26-2012, 07:08 AM   #3
dgreen
Should i just get all mogg front end parts would that be better?
Old 04-27-2012, 02:06 AM   #4
INSIDIOUS '86
Originally Posted by dgreen View Post
Should i just get all moog front end parts would that be better?
It will be about 471.45 with all moog and urethane bushings from energy suspension
Don't forget the cost of grease and labor for having your bushings and ball joints pressed.
http://www.summitracing.com/parts/MOG-K6247T/
http://www.summitracing.com/parts/MOG-K6143/
http://www.summitracing.com/parts/MOG-K6136/
http://www.summitracing.com/parts/MOG-ES409RT/
http://www.summitracing.com/parts/MOG-ES409LT/
http://www.summitracing.com/parts/ENS-3-3161G/
You need two inner and two outer tie rods, and two upper and two Lower ball joints
Total cost is $471.45
Old 04-27-2012, 02:11 AM   #5
INSIDIOUS '86
After this go with a one tone away bar up front with urethan middle bushings and stock side rubbers
Don't worry about bump stops or adjusting sleeves. More than likely the stock ones are just fine
Old 04-27-2012, 06:17 AM   #6
dgreen
awesome going to get all the moog parts in about 2 weeks ! thannks
Old 04-28-2012, 02:01 AM   #7
andrewmp6
I only use moog parts to me there ball joints last longer then other off brands i have tried before.
andrewmp6 is offline   Reply With Quote
Old 05-04-2012, 04:22 PM   #8
InLimbo
What INSIDIOUS 86 said, but go through Rockauto. Same parts 25-45% cheaper and if you google "rockauto coupon" you can find a code for another 5% off! I am looking to do my suspension soon too, here are part #s of what I have compiled so far. Not all inclusive I am sure. All #s are moog/timken parts.
My truck is an 85 if it makes a difference.
Upper ball joints K6136
Lower ball joints K6117T
Upper arm bushings x2 K6138
Lower arm bushings x2 K6137
Idler arm K6247T
Pitman arm K6143
Tie rod ends ES409RT x2 ES409LT X2
Tie rod adjusters ES2004S x2
Wheel bearings outer x2 SET3
Wheel bearings inner x2 SET6
Bearing seals x2 8871
Please feel free to add to this, I may have forgotten something. I only want to tear it apart once!
InLimbo is offline   Reply With Quote
