Junior Member
need part# for 4 core sb fan shroud
Is anyone running a four core radiator with a small block and 2wd from the factory? If so could you get me the part number for your fan shroud?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 04-25-2012 at 05:39 PM. Reason: spelling |
Re: need part# for 4 core sb fan shroud
I would like to know this too....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
me too
Posted via Mobile Device |
Before I found the correct deeper shroud for my 4X4, I ran a regular 2WD small block V8 shroud on the 4 core radiator and it fit fine. The fan just was outside of it because the engine sits back further on a 4X4 than 2WD. I don't have a GM part number but reproduction shrouds are readily available from various vendors.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Junior Member
I have heard the repop's are no good. Anybody have something nice to say about the repops and where they got theirs?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
Junior Member
ttt
Junior Member
ttt
![]() Join Date: May 2009
Parts book lists fan shroud as:
3901443 - 71-72 C Models w/350 V-8 w/HD Rad
My goal in life is to be as good a person as my dog already thinks I am - Unknown |
Junior Member
Gracias senior.
#10 | |
The above part number, "w/350 V-8 w/HD Rad", does that imply that there is a different part number for "w/350 V-8 without HD Rad"????
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
PN for all other 2wd sbc V8's w/o AC and/or HD Rad is listed as #3889079.
BTW, this is for '69-'72 trucks.
C/10 junkie
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" ![]() |
#13 | |
VA72C10
![]() Join Date: Mar 2008
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#14 |
C/10 junkie
Where typically is the part number located? Just want to know if mine are OEM.
#15 |
Junior Member
3901443 looks to be a big block shroud, I am going to double check it against one I have at home, I guess it will also work with a small block
#16 | ||
"I ain't nobody, dork."
I was going to purchase a repop shroud, but heard of the crappy quality... I talked to Wes at Classic Heartbeat, and he had a used OEM HD shroud in fantastic shape. Fits great.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#17 |
Junior Member
I hit him up before posting but he did not have one. Do you have the part number by chance?
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 Last edited by BB72CHEVKT; 04-30-2012 at 03:29 PM. Reason: add info |
#18 | ||
Let me go see if I can spy it on the shroud... BRB...
![]() Gary
#19 | ||
Without unbolting it... there's no visible numbers I can see.
Gary
#20 |
Junior Member
Thanks, I think it is on the inside where the fan goes so it may be impossible to see when bolted to the truck.
#21 |
Big block shroud should be 3924932.
