Old 04-25-2012, 05:02 PM   #1
gramps77
Deep 700R4 tranny pan
Im about to swap to a 700R4 from the th-350 and was planning to use the stock crossmember but move it and redrill for the other 2 holes.
Does anyone know if the deep pans can be bolted up easily with this configuration? I plan to use the Derale pan with the cooling tubes in it.
gramps77 is offline   Reply With Quote
Old 04-26-2012, 11:13 AM   #2
406 Q-ship
406 Q-ship's Avatar
Re: Deep 700R4 tranny pan
The crossmember will probably require a small amound of clearancing. My 74 with the 700R4 the pan is close to the relocated crossmember.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 04-26-2012, 11:55 AM   #3
Firebirdjones
I use the stock GM deep pans on both 400's and 4L60E's without a problem.
The aftermarket pans however, may or may not be tight.
Firebirdjones is offline   Reply With Quote
Old 04-26-2012, 12:13 PM   #4
gramps77
Thank you sirs.
Appreciate the feedback. I'll keep the grinder ready.
