Old 04-25-2012, 09:52 PM   #1
kgmunro
57 on 73-87?
Hey is anyone using a 73=87 frame for a 57 style chevy short/stepside truck? I was wondering if it would work...
kgmunro is offline   Reply With Quote
Old 04-25-2012, 10:50 PM   #2
blackdiesel
blackdiesel's Avatar
Re: 57 on 73-87?
it will work but you front wheels will stick out of the fenders, and the wheel base is allittle long, but can be fixed by drilling a new hole in the spring pearch for the center bolt to fit in moving the rear end forward a couple inch. And the front cab mounts will have to be raised 4". In my opinion there are better choices.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 04-25-2012, 11:29 PM   #3
azsnow
azsnow's Avatar
Re: 57 on 73-87?
Agreed, there are better choices out there. I do like these chasis for a 4X4 modification though, parts are really easy to come by!
azsnow is offline   Reply With Quote
Old 04-25-2012, 11:38 PM   #4
sabre67
Re: 57 on 73-87?
OK Im listening what are the other options? Im new at this too Thanks
sabre67 is offline   Reply With Quote
Old 04-26-2012, 04:10 AM   #5
drivea55
drivea55's Avatar
Re: 57 on 73-87?
few years ago we actually built a 58 using a 1985 chevy blazer rolling chassis. Width was not an issue seeing we kept it a 4*4 vehicle.
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 04-26-2012, 06:34 AM   #6
kgmunro
Re: 57 on 73-87?
How about using offset rims? Will that make a difference on the front fender/tire issue? I can get a chassis that is almost done (lowered and c notched) really cheap from a friend, that is why I am considering it...
Old 04-26-2012, 01:19 PM   #7
blackdiesel
Re: 57 on 73-87?
if you used 17" or bigger off set wheels might work but smaller hit on the brake caliper
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 04-27-2012, 08:21 AM   #8
kgmunro
Re: 57 on 73-87?
Has anyone ever grafted a camaro clip on one of these frames??
Old 04-27-2012, 08:38 AM   #9
63 & 64 Bowties
and a few others
Re: 57 on 73-87?
Here's about 30,000 results....
http://www.google.com/#q=site:67-72c....,cf.osb&cad=b
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 04-27-2012, 10:16 AM   #10
buggy5872
buggy5872's Avatar
Re: 57 on 73-87?
Put a 70's camaro clip on the original frame and the camaro rear under the back. There's a ton of them out there and lots of info on the net. It is really simple to do if you can weld.
buggy5872 is offline   Reply With Quote
Old 04-27-2012, 01:21 PM   #11
kgmunro
Re: 57 on 73-87?
the frame under the truck is 1 ton...there are none left around this area that are 1/2 ton...that is why i ask! The 80 truck frame is there and i have a camaro clip.
Old 04-28-2012, 01:20 AM   #12
Breader
Breader's Avatar
Re: 57 on 73-87?
My 59 has a 73 c10 front clip grafted to it. the guy I bought it from never finished it but I like where he was headed with it. and like you I'm also considering doing a frame swap because my fab skills are not as good as his and I just don't wanna risk it.
Breader is offline   Reply With Quote
Old 04-28-2012, 10:57 AM   #13
mr57
mr57's Avatar
Re: 57 on 73-87?
Not sure if Lothar Weber is still around the Brandon area, try find him, or one of the other old 5-6-7 club guys. Don Cuvelier in Killarney is another one that comes to mind. One of them should be able to find you a decent frame.....
mr57 is offline   Reply With Quote
Old 04-28-2012, 11:55 AM   #14
74 stepside
74 stepside's Avatar
Re: 57 on 73-87?
Might look into a S10 frame. I know they fit under 47-54 trucks, but not possitive on 55-59s. Also a camaro clip works great too. If you went the camaro clip, try and swap the rear end to match. Either way, theres going to be fab work on body mounts or on core support of camaro clip.
74 stepside is offline   Reply With Quote
Old 04-28-2012, 10:21 PM   #15
buggy5872
buggy5872's Avatar
Re: 57 on 73-87?
You can put the subframe on a 1 ton frame. The frames are the same width no mater what series truck. The frame might be thicker and a little taller but I am not sure. The rear springs would have a lot more leaves but you could take a bunch of them out to get a better ride. Check out some pictures of my frame when I put the camaro clip on. http://rides.webshots.com/album/578128249XNyAVS
