05-09-2003, 10:32 PM | #1 |
my carb linkage
I bought some rod ends from summit and got a piece of steel rod. I got a friend of a friend to bore a hole and thread it. What do you think?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
05-09-2003, 10:41 PM | #2 |
looks nice,
i really like your valve covers, where did you get them and how much green? david
1969 K10 Custom 10 1997 Z71 2006 Volkswagen Jetta TDI 2006 King Ranch 1980 Wife |
05-09-2003, 10:45 PM | #3 |
they came from a gm parts place. $120 i think. But you may be able to get them from summit now, not sure.....
05-09-2003, 10:47 PM | #4 |
thanks for the info, i'll have to go to a dealership tomorrow,
keep us posted on you kick a$$ truck david
05-09-2003, 10:56 PM | #5 |
haha, thanks for the complement
05-10-2003, 04:38 AM | #6 |
linkeage looks really good. i just bought a cable pedal from a board member to put the lokar cable in there. i think i like yours just as much. now i have to think about which one i'm gonna put in there
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
05-11-2003, 12:37 AM | #7 |
its all about the +6 inches
I've always wanted to do that...I'll have to get off my butt one day and do it.
Does it feel better nw? A little smother? |
05-11-2003, 10:36 AM | #8 |
I don't have anything to compare it to. We stripped the truck down to a bare frame about 6 years ago. It had a completely different motor and carb set up, so I cant really compare it to anything. There seems to be a hard spot, if you rev it up and let off it, the throttle stops bout 2,000 and then falls very slowly. I don't know if the rod is binding or the shaft on the carb itsself is sticking. The carb had set for a long time before I put it on my motor.
05-12-2003, 11:09 AM | #9 |
user # 2756
Looks great! As far as the hard spot maybe you need a heavier return spring?
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
05-13-2003, 01:17 AM | #10 |
I was thinking about trying different springs. I have dual springs from a lokar kit, but the pedal feels real light when you step down on it. Not the usual stiffness from most GM throttles. I've never seen return springs with rates on them. As heavy as my foot is maybe I need to rip one off the storm door, that would definately yank it closed!
05-13-2003, 02:15 AM | #11 |
former desert rat
Location: salt lake city, utah Home of the 3 M's Mormons, methlabs and minivans
Your linkage looks kick a$$. Nice valve covers as well. Any more pics of your engine/ truck?
94 Chevy Silverado Ext cab 4/6 drop w/ 18's and 2500watt system (work truck). 67 Chevy swb under const. frame off custom, 20's, bagged and a large rat under the hood,and a 1940 Chevy truck under const. |
05-13-2003, 10:17 PM | #12 |
I have some pics, excuse the crappy digital camera. I'm not gonna be on here though for the next few days, I'm in the process of moving and time for the computer to go. I can't get on at work anymore, they are cranking down on everyone.
Details: Victor Jr. intake, corvette brackets/pulleys, flexalite fans
05-13-2003, 10:18 PM | #13 |
1
05-13-2003, 10:21 PM | #14 |
2
05-13-2003, 10:23 PM | #15 |
We painted the firewall and the inside of the cab. The rest is in PPG DP 90 sealer/primer. Waiting on a little more time/money to finish painting the truck.
