Old 04-26-2012, 02:37 PM   #1
Breadstick
Removing window trick
I just replaced the window weatherstrip in my 64 and I was using the shop manual as a guide. After wrestling for a while, I finally got it off. I still had the fuzzies in when I removed the window, so I couldn't get a great look. I was dreading how long it would take to get back in, but when it was time I learned something. I rolled the window regulator all the way up and it looked like I could just slide the window right on the tracks. I tried it and it worked perfectly. I rolled the window all the way down and put the fuzzies back in and it was MUCH easier than the way the manual said. I can't believe how much.
I hope this helps someone.
Breadstick is offline   Reply With Quote
Old 04-26-2012, 09:04 PM   #2
64shortbox
64shortbox's Avatar
Re: Removing window trick
Breadstick,
Thanks for the post. I definately need to replace my felts, etc. and your info will come in handy. I also plan on installing power windows so I'll definately use the information you provided.
64shortbox is offline   Reply With Quote
