Old 04-26-2012, 03:33 PM   #1
rab5xl
Coil spring question
Anyone had good or bad experiences using 3" drop coils with 3" Bell Tech spindles? I have an 87 c-10 1/2 ton running 17".
Thanks for any input.
rab5xl is offline   Reply With Quote
Old 04-26-2012, 07:15 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Coil spring question
Some say a 3" drop spring is tough to get the front end alignment correct.
Keith
Convert to disc brakes.
Old 04-27-2012, 01:34 PM   #3
rab5xl
Thanks much.
Old 04-27-2012, 04:07 PM   #4
cdowns
cdowns's Avatar
i've heard that with a 3" drop spring if you go over a large bump at speed the spring can cum flying out and your left diggin payvement with whats left of your suspension
Old 04-28-2012, 01:44 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
I've cought air in my truck with 3 springs and this hasn't happened.
If your real worried about that use a limiting strap
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-28-2012, 05:28 PM   #6
Pro Performance
Pro Performance's Avatar
The 3" springs and 3" drop spindles will put the arms real close to the ground. Probably would be fine as stated above, but little too close for me without adjustability like of an air suspension.
But, I bet it looks damn good.
Pro Performance is offline   Reply With Quote
Old 05-01-2012, 03:24 AM   #7
Andy4639
Old member
Andy4639's Avatar
Talking Re: Coil spring question
I have the droped springs in mine and have never had a issue with them.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
