Old 04-26-2012, 04:10 PM   #1
byates2
byates2's Avatar
Radiator core mounts?????
did i put these on right?
I put the square washer first. then metal, then in between the core support and frame, i put rubber washer then metal, then on the bottom i put metal and that big rectangular washer.
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 04-26-2012, 04:36 PM   #2
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: Radiator core mounts?????
The square washer goes on top of the core support to keep the bolt from spinning while tightening the nut on the bottom.
Then it is your radiator support.
Then rubber bushing with a steel washer under it. That sits on top of your frame bracket.
Then under the frame bracket will go another steel washer, then rubber bushing, then steel washer again, then the kind of triangular shaped piece, and finaly the bolt. Once you tighten the bolt you bend the norrow side of the triangular shaped piece over to keep the bolt from backing off. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-26-2012, 04:42 PM   #3
Classic Heartbeat
Here you go..
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 04-26-2012, 06:08 PM   #4
byates2
byates2's Avatar
Perfect, just what i needed, thanks a ton!!!
Old 04-26-2012, 06:12 PM   #5
72tutone
Would you have another one of those for a 72? I am getting ready to put mine on, and they were destroyed after 40yrs and just fell apart.
72tutone is offline   Reply With Quote
Old 04-27-2012, 02:35 AM   #6
Classic Heartbeat
I will look in the morning. If not I can make one easy enough. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 04-28-2012, 05:41 PM   #7
Classic Heartbeat
Small picture but here is a diagram. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 08-01-2013, 07:41 PM   #8
JointTech
JointTech's Avatar
ok sorry to necro this thread but does the radiator have to come out to get that bolt out? I cant see anyway of getting to it otherwise. the nut is right there but i dont see how to get to the top of that bolt to take it out and put the new bolt and washers in?
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
