What power steering hose, 1978 GMC, 91 Suburban 350
What power steering hose should I use?
Truck is 1978 GMC 2wd 1/2 ton. motor is out of 91 Suburban 4wd 350 1/2 ton. I have the original 78 pump and lines. The 78 pump could not go on the 91 serpentine setup. Are there adapters out there? Or a vehicle that would have the right hoses? |
Re: What power steering hose, 1978 GMC, 91 Suburban 350
ok on the back of the pump, where the hose screws into, has a larger nut. you can unscrew that out, and swap them between pumps, and keep your old line and setup. there is a spring behind it, as well as a little floating valve assembly. not a big deal though if you're careful.
I've even swapped these between chevy and dodge p/s pumps, when I put the cummins in my truck.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
#3 | |
