Power steering conversion problems.
Thanks to Sharpie, I was able to get my hands on a short water pump power steering pump and bracket. I put on the back bracket to just put the pump in place to see how things line up.
The problem is I already had to put 2 washers for spacers behind each bolt of the crank pulley to get it to line up with the water pump pulley. Now looking at the power steering pump, I need to come out another 1/2 inch at least, not only that but the pulley of the PS pump is not even at the same angle as the other two pulleys.... Any thoughts? ![]() |
![]() Join Date: Oct 2010
Re: Power steering conversion problems.
you need the red pulley in this picture and you only need a single groove upper pulley unless your running AC or something else
Chuck ![]() |
Yeah, i got the double pulley on the water pump because the stock water pump pulley was too big and it was interfering with the crank pulley.
Isn't the red pulley in the middle for long water pumps? I don't think it will line up with my water pump. |
I have this one laying around. I think it is the same size as the said "red one".
![]() Join Date: Apr 2008
You are one grove short on your crank pulley probably because your truck did not come with the P.S. option. Get a crank pulley with one more grove and you should be fine. Do not shim anymore out.
Changing the water pump pulley size changes the speed at which the pump rotates. Don't go too small with it or you will end up with cavitation at high revs, or it will start collapsing your lower radiator hose at higher speed.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 04-27-2012 at 01:33 AM. |
Active Member
![]() Join Date: Jul 2007
If it were me doing that conversion, I would start combing the salvage yards for a vehicle (same or similar engine) and yank all the components out of it - including the harmonic balancer and pulleys, fan, p.s. pump and all brackets if able to do it. There's bound to be one somewhere and it just takes time to locate it.
When I converted my six cylinder I had a chance to grab all of the components from a six cylinder El Camino but didn't do it for lack of cash. I later pieced it together from different vehicles and it turned out to be a pain in the you know where to align everything. |
English Chevy Owner
I ended up buying a complete used set of pump and matching pulleys as my truck came with a bodged on later power steering pump and pulleys that didn't quite line up properly. It was much easier to throw on a complete set you know was going to work.
Phil '67 C10 long fleet. 350/TH350, 4 bbl Carter, K&N, Dual exhaust, loads of stuff coming soon 2001 S10 Blazer Daily Driver, bone stock 4 door 4x4 with manual transmission |
Ya, I searched the salvage yards originally for a PS pump and all the components. All I found were Long water pump versions of everything.... Living in a relatively low population rural area, that tends to happen - only get what you don't need.
Old member
Here is what I have. 305 HO motor out of a camaro 86-87.
You need the crank pulley with 3 grooves. Inner belt is for the alternator Middle is AC belt Outter is for power steeriing. Sorry about the pictures it's hard getting down in there and snapping a shot. ![]() ![]() ![]() ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
I would agree, the best thing to do is get all the pulleys off the same truck/car. If your not able to do that, get a crank pulley with 3 grooves like someone else said.
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
#11 | |
Sierra Grande Club
There's a guy in AZ that sells pulley's on Ebay and has all kinds of pulley's for our truck's.
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Sierra Grande Club
Here's a picture of the shims for reference. I've also have lots of pictures documenting this common problem.
#13 |
How much for shipping to 83634?
