looking to set up rear air bags on my truck, new to site so need some advise, just got my truck about 2 months ago, ive put power windows, power door locks, one pieac driveline, and a serpentine belt set up from gmperformance, and ijust got my 2-1/2 inch drop spindels, but ive never really done anything with air bags , any input will help thanks,
2WD Jimmy
![]() Join Date: Mar 2005
Re: rear air bag set up
Call Early Classic Enterprises in Fresno. You will thank me.
Would you like to lower your Classic and still be able to haul heavy loads or pull a large trailer? We’ve designed our Rear Air Ride Suspension Kit to allow the best of both worlds: Heavy hauling and a low rear stance without compromise. This kit is a direct replacement of your rear coil springs and can be inflated manually or with the optional on-board compressor system. Included in the system are the required Super Track Bar Kit, Shock Mount Relocator Kit and Two KYB nitrogen gas shocks. Rear Air Ride Kits (#902-6572AIR Kit includes Super Track Bar Kit, Shock Mount Relocator Kit and 2 Rear KYB Shocks. Does not include #902-5095AIR Rear Compressor Kit). (#902-5095AIR Rear Air Suspension Compressor Kit includes Tank, Gauge and Switch.) -------------------------------------------------------------------------------- |
do u have a phone number for them, ill be in fresno on the 10-11 of next month maybe ill stop by there shop
1-559-291-1611 speak to Stan.
VA72C10
![]() Join Date: Mar 2008
How low are you planning to go? Are you going to notch the frame? Small c-notch or large step notch? If no or small notch you can simply put the bags where the springs are and drill extra holes for the airline then install shock relocators and a longer panhard bar...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
thats my truck, i want to just do a minor c/noth i like it just as it is, just wanting to put bags , in case i tow something,or if i have a heavy load |
![]() Join Date: Sep 2011
What size tires and how much drop do you have on your ride? I like the stance, and good looking truck I have a set of the aluminum slot wheels on my suburban also.
tire are p255/60r15 102s and on the drop not to sure ill figure it out for u,
it rides very smooth, after i put the 1 pieac driveline on it a local shop did it and they did a very good job |
had to put this sticker on it |
laying low
![]() Join Date: Mar 2001
Your truck sits good now. Those slots. They look like the set of ET polished slots I had on my first truck in the early 70s. Sure wish I still had them. I see you have shortened the truck. Good move.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
