What headers to use?
I'm looking to get a det of headers for my 72 C10. I'd like to get a set of mid-length headers to keep as much ground clearence as I can. I'm not having any luck finding any listed for a 66-87 truck so, I'd like to know if anyone has tried a set of 88-95 headers on 66-87 truck?
http://www.ebay.com/itm/160749951469...84.m1438.l2649 It looks like to me that they would fit. Anyone have any ideas? |
Re: What headers to use?
If you don't get a set of shorties I will guarantee you'll loose ground clearance no matter what brand/year you go with. I you are bagging then it's a concern. If you are not then just how low are you going? Mine will be 4.5/6 and I expect to use extreme caution with speed bumps and such. I have Hooker Super comps with a 1 7/8" tube. Even with the 1 5/8" tube I believe there would be issues. Shorties would be the way I would go if I changed. I had mine left over from a drag car I parted out so I just slammed them on. We'll see how it goes.
Sisyphus was my mentor!
![]() Join Date: Sep 2002
I've only started my truck just one time since I installed these headers, but so far I like them a lot & they sit within the frame rails.
http://67-72chevytrucks.com/vboard/s...d.php?t=314836
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 04-27-2012 at 10:26 AM. Reason: spellin |
#4 | |
I forgot to say I have Trick Flow heads with angle plugs. That's what is making this harder to find a set of headers.
I have them installed on trick flow gen 1's with angle plugs & they fit great.
passthebuck ![]() #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car |
#7 | |
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
So let me get understand you correctly, you did get the 88-95 headers to work on your 66-87 truck?
#9 | |
More Pictures
#10 | |
Sierra Grande Club
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Just curious as to whether these would also fit with a little frame trim.
http://www.ebay.com/itm/Header-GMC-T...d8e8a9&vxp=mtr Stainless with the (better?) ball flange; and similar money. These are manifold replacements; and made to bolt up to an existing Y-pipe. But if you had the Y-pipe stubs and flanges??? Looks like 1 3/4" though, not 1 5/8".
1971 C10 SWB 350/350 A/C PS PDB |
#12 | |
#13 |
Okay, I see the number one and two cylinder tubes go under as opposed to over.
Is that what will interfere with the frame mount? Posted via Mobile Device
#14 |
Yes exactly
