3spd saginaw to 4 spd saginaw- will this work?
My 74 shortbox steper has a 3 speed that WAS on the tree but the po moved it to the floor. He told me and I believe that it the original trans.
My questions in will the 4 speed pictured below work? If I go and look at this what do I look for? Is $100 a decent/fair price? Anyone ever had a 4 speed rebuilt? Expensive? Thanks for the help and info!
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
![]() Join Date: Oct 2006
Re: 3spd saginaw to 4 spd saginaw- will this work?
I did this to a 1974 Nova back in 1987! It was a direct bolt in for me,as long as both trannies are the same length/output spline count,it should swap right in.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
AND you will need a FLOOR SHIFTER!
He said the previous owner moved the shifter to the floor
Semi professional heavy equipment operator Amateur mechanic |
Absolutely!
Did that on my 80 pickup when it was new. Went from a Saginaw three speed on the tree to a Hurst floor shifted four speed with a 3.11:1 low gear. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Are you saying I'll need a shifter because its a 4speed. And that I cant use the 3 speed shifter I have now?
#7 | |
Sorry for the possibly stupid questions. This will be my first time with the stick stuff. Thanks for the help
You will have to get a different shifter. The three spd will only have 2 levers,the 4spd will have 3 and different linkage.
every thing else will work.GM made a three speed overdrive too,trying to remember how it looked. summit racing sells the hurst shifters and the saginaw linkage kit. you can take the side cover off and look inside to dee if anything looks broken. if you don't know anything about them,do not take them apart. you'll be lookin for days tryin to find all those needle bearings. if everything looks fine and there is no sign of water damage, then you can replace the seals and try it out. there is a seal in the front behind the cover(it installs upside down) and a tailshaft seal. by the way,make sure you mark the front cover so it will be in the same place when you reinstall it. there is a small opening beside the front bearing that must line up with the "port" in the cover.
make sure it turns freely,you will have a little bit of movement in the front shaft because the needle bearings are oil fed. if it fells like it has rought spots,then it needs to be rebuilt.
I run a Saggy 4 spd out of a Vega in mine. 1,2,3 are close ratio, then you hit 4th and it goes 1:1 and a major drop in rpm's. Thru hard city driving I hardly ever hit 4th. But I'll tell ya this much, from red light to red light it takes off like a scalded dog with his head on fire and his butt catch'in.
#12 | |
#13 |
No No
I ran a saginaw 4 speed for about 3 days way back when I was a retarted kid and it was a waste of my time and money I dident have. I was running a sb and a 3:42 ratio rear end on stock size tires. 1st gear was useless about 10 feet and shift I had better results using it like the 3 speed I had in it before.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
#14 | |
#15 | |
Do you not think this is a good choice?
#16 |
#17 |
people like the four speeds for the sound of changing gears....the more the better. It's all 1:1 in high gear anyways. it's really your preference
#18 |
I think the bore in the bellhousing is bigger on the truck the the cars;so you MAY have some clutch alignment issues;measure the od of the front bearing retainer on the 2 trannies.
The bolts may hold it close enough ...but you could have chatter if it is off center. |
#19 |
Anyone know if the bellhousing are the same between the straight 6 250 and the sbc?
#20 |
Mine was. In the same Nova, it started life as a 250/3 on the tree. It became a 383,4spd......I used the same starter,bellhousing,linkage and clutch.
#21 | |
No No
If you are replacing a existing 3 speed it will bolt right in and its the same spline so clutch wont be an issue and neither will the clutch linkage you can seriously unbolt just the trans and slide the new one in place. As far as the other question I dont remember what ratio 1/2/3 are but on all of these 3 and 4 speeds its 1:1 in high so there will be no diff once you slide it into 4th over the 3 speed.
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler Last edited by SSC's76; 05-02-2012 at 11:31 AM. |
#22 |
![]() Join Date: Apr 2001
if you REALLY wanted a unique cruiser you could find an old OD unit that was found behind many of the cars of the late 50's and early 60's (trucks to till 69 i believe) and retro fit it on the rear o fthe four speed... There are online articles on doing this and it would be the best of both worlds as long as you arent going to abuse it. LINKY
Kind of a neat deal and would be unique..... OR find the MY6 OD 4speed used in GM trucks from 81-87..... --Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
