04-27-2012, 12:42 PM | #1 |
Stabilizer Bar? Its Purpose?
I noticed this bar coming from my axel to my frame has been cut off. I took this picture off the one on my parts truck. Do I need this? What was it's purpose?
04-27-2012, 12:43 PM | #2 |
Re: Stabilizer Bar? Its Purpose?
*axle
04-27-2012, 02:29 PM | #3 |
Confirmed Truckaholic
It keeps you rearend squared.
1968 50th STEP SIDE SHORTY, 350/350, a/c, ps, p,b Daily Driver, 1970 Cst short fleet, all black, 350/350, 1970 2wd Blazer, 2wd, 6 cyl. 3 spd, original, now a 454, 350turbo, 3.73 posi, on the road 1971 2wd fleet shorty, 454, 700r4, 3.73 posi, SOLD to 67OLDSTYLE72 "My rig's a little old but that don't mean she's slow" - SAWYER BROWN's Six Days On The Road SEMPER FI "I use to be a lean mean fighting machine, but now I'm a huffin, puffin, over stuffin love muffin" |
04-27-2012, 02:47 PM | #4 |
But i notice on pics on here a lot of guys with 69-72 blazers don't have one? What's up with that?
Posted via Mobile Device |
04-28-2012, 12:15 PM | #5 |
Panhard bar to keep a 2wd axle centered i.e. coil spring axle. Most blazers/jimmy are 4wd leaf sprung axles...no need for the panhard bar.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) 2003 K2500HD 8.1/Allison1000/NP263 |
04-28-2012, 06:02 PM | #6 |
Roadtrip!
Yes you need the panhard bar. It keep the rear solid with the rest of the truck. Any of these trucks with coils and trailing arms has it. Leaf spring trucks did not have it.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
04-28-2012, 09:59 PM | #7 |
Well that pic was of a 72 Chevy truck with coil springs. But my blazer of course has leaf springs, so should I connect a pan hard bar? Or is there no need since I have leaf springs?
04-28-2012, 10:05 PM | #8 |
Do not install it if you have leafs. My guess is that your rearend was swapped at some time with one from a coil spring truck. Do your leaf spring pads look like they have a non-factory weld?
Is the bracket for the bar on your frame?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
04-29-2012, 12:43 AM | #9 |
Good points, I guess my rear end couldve been swapped from a truck, but it is a 12 bolt. Did trucks come with a 12 or 10?
-haven't noticed welds where the pads are, but i will look. And no the bracket isn't there, but on the side of the frame it looks like something has been cut off. But I noticed that same mark on the frame of the truck the above pic is from. I will post pics of each outer frame so you can see what I mean. Posted via Mobile Device |
04-29-2012, 01:58 PM | #10 |
Blazers came with a 12 bolt rear regardless of 2wd or 4wd. With the 4wd, the rear had leaf springs and they keep the rearend centered. No need for a panhard bar with leaf springs.
04-29-2012, 02:07 PM | #11 |
So did any blazer come with coil springs? Or is my axle obviously one that haas been swapped in at some time?
04-29-2012, 02:42 PM | #12 |
Only 2WD Blazers came with coil springs and trailing arms.
1954 Ford F-100 1956 Chevy big window 1970 4x4 Blazer CST 1987 Land Cruiser 1990 Chevy K3500 454 |
04-29-2012, 02:44 PM | #13 |
Ok I see! Thanks guys!
05-01-2012, 07:48 PM | #14 |
Junior Member
Watch out for the hornet's nest next time you go under that parts truck!!
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
05-02-2012, 12:57 AM | #15 |
I know! Risk anything to get a part! Haha
