Old 04-27-2012, 01:19 PM   #1
Breadstick
Adjust gas gauge?
After reading the "how many in-cab tanks" thread, I realized that my gas gauge has to be off because I filled it up from near empty the other day and only put about 9 gallons in it. On the bright side, I'm getting better gas mileage than I thought. However, I don't like the fact that I don't have accurate readings, which could be problematic on trips. Is there a way to adjust the gauge somehow to make it read correctly?
When I fill up the tank, the needle goes to the far right hash mark in on the gauge, but when I turn off the ignition the needle goes so far left that I can't see it in the viewing window. I figured that the far right mark was full and I would fill it up when the needle goes between the middle and left mark, but I'm starting to think that I'm off.
Breadstick is offline   Reply With Quote
Old 04-27-2012, 01:28 PM   #2
1963c-10
1963c-10's Avatar
Re: Adjust gas gauge?
The guage should go past the full mark when full and go completely off to the left when the ignition is off. There is no way to adjust the fuel guage. If its not reading correct, you will probably need a new sending unit, or have the guage rebulit. The original guages and sending units are 0-30ohm
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-27-2012, 01:31 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
This might be a pain, but may help. For the 0-90 ohm sending unit conversions I do for people who install aftermarket 90 ohm gauges, I suggest making all of the connections to the sending unit while it is outside of the tank and run the float arm through its full range of movement slowly while watching the gauge to confirm working condition and help with calibration. You may find that you have something (debris) obstructing the float arm or the float might have a pin hole and is filled with fuel, which is hard to tell without pulling the sending unit.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-27-2012, 05:12 PM   #4
Breadstick
It seems like the easiest troubleshooting would be to replace the sending unit. How difficult is this? It seems like it will be pretty simple to do but I've never done it.
Old 04-27-2012, 06:41 PM   #5
gimmy 64
do like me and alot of others on here and use a yard stick. lol.
gimmy 64 is offline   Reply With Quote
Old 04-27-2012, 10:18 PM   #6
Chevysdominate
Chevysdominate's Avatar
After thinking about it a bit you might be able to use a voltage regulator on the power wire to the gauge. The fuel gauge works kind of like an ammeter. If you cut the voltage down to maybe 5-6v you could get a more accurate reading. Using a variable regulator you could at least set it to let you know when its actually empty. I'll try to dig up a 0-90 ohm sending unit and test it out.
Chevysdominate is offline   Reply With Quote
