Old 04-27-2012, 04:55 PM   #1
Chevy623
Chevy623's Avatar
Check engine light.
My Blazer drives fine all over town but when i reach highways speeds the check engine light comes on and stays on untill you turn the truck off. when you turn it back on it is no longer on. i can't tell you how fast i am going when this happens because the speedo is currently non-op. the tranny does feel like it is not shifting properly at these speeds. it is a loud truck and when it comes time to shift, it gets really baffled sounding, and then loud again when it shifts. it is a 1991 with a 350. i could really use any ideas as to what the problem is. thank you.
Jesse.
Chevy623 is offline   Reply With Quote
Old 04-27-2012, 05:00 PM   #2
Chevy623
Chevy623's Avatar
Re: Check engine light.
Btw, transmission has fluid in it. just in case that was your first thought lol.
Jesse.
Old 04-28-2012, 09:04 AM   #3
Stringer
Have you checked to see if any codes are stored? Here's a thread that'll tell you how, if you haven't done it before.
http://67-72chevytrucks.com/vboard/s...d.php?t=405077
I have that symptom - EGR code shows up. If that's the case, be careful about which EGR valve you buy. Not sayin it is....just a possibility.
Stringer is offline   Reply With Quote
