04-27-2012, 05:14 PM | #1 |
4x4 frame
Is there any differance between a 4x4 1970 k10 frame and a frame from a 1972 4x4 k30 frame ?
04-27-2012, 05:41 PM | #2 |
Re: 4x4 frame
04-27-2012, 05:51 PM | #3 |
Re: 4x4 frame
I have not bought it yet thats what he is telling me the truck was i would think that the frames are the same 10-30
04-27-2012, 06:18 PM | #4 |
Currently Blazerless
Re: 4x4 frame
K-10 and K-20 frames are the same..there were no K-30s, the only way you could get a K-30 back then was by going thru NAPCO and they would have started with a C-30 truck and converted it.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-27-2012, 06:26 PM | #5 |
Re: 4x4 frame
They are not the same and there were no known factory "K30" trucks for 67-72.
These are the different PICKUP TRUCK frames as I understand. Any corrections are invited. C/10 115" COIL C/10 115" LEAF C/20 127" COIL C/20 127" LEAF C/30 133" LEAF (Longhorn C/20 & C/30) C/30 133" LEAF (9' Stepside) K/10 115" K/10 / K/20 127"
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-27-2012 at 06:30 PM. Reason: oops |
04-27-2012, 06:43 PM | #6 |
Re: 4x4 frame
So if i have a c-10 pickup 4x4 the c-20 & c-30 frames are differant?
04-27-2012, 07:14 PM | #7 |
Re: 4x4 frame
I guesse I shouldnt have used the K to referance the 4x4 since that started in 73. No they would not be the same, you could have a C/10 4X4 or a C/10 2X4 in these years as the C just denotes a custom series. A C/30 frame is about 1" taller and slightly thicker than a C/10 or C/20 frame...plus either 6" or 30" longer than the 10/20 series...confused yet? I am!
04-27-2012, 07:21 PM | #8 | |
Re: 4x4 frame
So, if you have a factory K/10 lwb then it is the same as a K/20 frame. However C/10 lwb, C/20, C/30, C/20-30 Longhorns are different and different from each other as well.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-27-2012, 07:24 PM | #9 |
Vintage 4x4s
Re: 4x4 frame
Tim, are you sure the K10 and K20 lwb frames are the same? I was reviewing some literature the other night and it listed the "section modulus" of the 2wd frames as different between a lwb c10 and c20 which implies a slightly thicker frame. I will look again and see if it had the values for the 4x4's.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
04-27-2012, 08:17 PM | #10 | |
Re: 4x4 frame
Very good. But yes I did review that number as well. Here is the list below. As I understand C/10 swb and K/10 swb have the same section height. C/20, K/10 lwb and K20 have the same but taller section height. C/30s and Longhorns are still taller yet. Its important to remember that even though many models have the same section height and/or modulus the rails may have different shapes and spacing. C/10 115" 2.98 C/10 127" 2.98 C/20 127" 3.71 C/30 133" 5.05 C/20-30 Longhorns 5.05 K/10 115" 2.70 K/10 127" 3.48 K/20 127" 3.48
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 04-27-2012 at 08:27 PM. Reason: can't spell tonight :-) |
04-27-2012, 09:11 PM | #11 |
Vintage 4x4s
Re: 4x4 frame
Good info Tim, makes sense now why the GVWR is that much higher for a K10 lwb than a C10 lwb.
04-27-2012, 09:55 PM | #12 |
Re: 4x4 frame
Thanks, It also underscores why I prefer converting a Longhorn vs. beefing a K/20. Its more than just six inches ahead of the rear axle.
