04-27-2012, 05:32 PM | #1 |
need help with trans issue
found a trans out of a 95 camaro v6 will it fit behind a v8 looking for a 5 spd or 6 spd for my 57 chevy pickup thanks
04-27-2012, 06:21 PM | #2 |
Re: need help with trans issue
Unless you are going to run bucket seats you may run into shift handle clearance problems with a Camaro trans and bench seat. At least that should be a consideration.
Do you know what engine was in front of the transmission? that may make a difference in the way it hooks up to an engine and be an issue. If it is a T 5 like this one on Ebay you should be able to hook it up somewhat easily. http://www.ebay.com/itm/T5-BORG-WARN...92fb89&vxp=mtr |
04-27-2012, 09:02 PM | #3 |
The bellhousing on the transmission will not bolt up to a V8. Also the T5's had a different spline count for V6 and V8...IIRC 17 spline for V6 and 27 spline for V8.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
04-27-2012, 09:20 PM | #4 |
thanks really havnt throught bout motor yet i do u it will be a mild small block i guess i should find one from a v8 i guess really nothn out here in va without spending 1500 to 2000 $$
