Old 04-28-2012, 01:32 AM   #1
edflores
4-1/2" Z, How much to cut for the motor
Im installing my 350/700r4 back into my 78 c10.
I removed the trans tunnel so far, I will cut the rear for the drive shaft.
Im wondering if anyone else has a 4-5" Z that can tell me What clearance issues I will run into.
Will the HEI distributor clear?
Will the transmission clears?
Anything else?
edflores is offline   Reply With Quote
Old 04-28-2012, 02:08 AM   #2
broey
Square
broey's Avatar
Re: 4-1/2" Z, How much to cut for the motor
Sorry, wish I had the answer for you! But I'm curious why you did such a large z?
Squarebody Syndicate
broey is offline   Reply With Quote
Old 04-28-2012, 11:47 AM   #3
edflores
previous owner though it was necessary.. He was trying to lay out on 26's.
Old 04-28-2012, 11:53 AM   #4
Mad Rods
Chevy Only Tx
Mad Rods's Avatar
Just curious what size are those wheels u have on it now?
Chevy Only Tx.........
Mad Rods is offline   Reply With Quote
Old 04-28-2012, 12:22 PM   #5
edflores
24's. BLF uniball arms. As you can see, its set up to lay 26's. Firewall tubbed for 26's.
Old 04-28-2012, 01:56 PM   #6
broey
Square
broey's Avatar
I wonder if you will have exhaust issues, like you might have to add length to the headers so they come down low enough to clear the cab floor? also, you may want to pancake your crossmember so you can drop your engine down a little bit.
Old 04-28-2012, 03:04 PM   #7
cory d
cory d's Avatar
thats the biggest Z i have ever heard of
cory d is offline   Reply With Quote
