![]() Join Date: Apr 2010
Break in oil
Is this a good break in oil? Joe Gibbs 01814 BR-30 5W-30 Break-In Motor Oil. Thanks
Re: Break in oil
I used their original break in oil last year in my 396 and it's running strong today.i believe the only difference is the viscosity.the original is 15w-50 .i think you would be safe with either one imho
Posted via Mobile Device |
Re: Break in oil
thats what i was recomended to use just have a hard time with 7 dollars a quart
Re: Break in oil
I've always used what ever (no cheapo junk) I was going to run and never have had issues. Done that with mild daily drivers to 10,000 rpm race motors. Just change it after break in. My unsolicited .02 worth
It's Better With Nitro
Re: Break in oil
Yes, the Joe Gibbs products are good...a little pricey, but good. If it's easy to find, I use the Brad Penn break-in and assembly lube on all of my hot rod and race engine builds.
