![]() Join Date: Jan 2001
Are 3speed flywheels and 4speed flywheels the same?
Need a little help finding the correct flywheel for my
67 c10 250 with 3 speed on the column. I found this part number 04398 ATP brand but its says for A four speed manual. Mine is a 3 speed manual. Thanks John Posted via Mobile Device
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
Re: Are 3speed flywheels and 4speed flywheels the same?
Should be the same, I just swapped the 3 speed in my 72 for a 4 speed out of my 70 burb parts truck. The 72 has a 307 the 70 had a 402 originally, Flywheel looked to be the same. I bolted the 12 inch clutch from the burb straight to the flywheel on the 307. Good luck with it, I had to make the rear driveshaft section to get the right length. 3 speed has a slip yoke, 4 speed has a fixed yoke.
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
