Old 04-28-2012, 09:49 AM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
3 speed to 4 speed od switch few ?ss
ok i have finally saved up a little money and am thinking about putting the 4 speed od MY6 trans from the 80s chevy trucks in my 69 in hopes for better gas mileage. from what i have heard its a direct bolt up from my old 3 speed. my questions are what else will i need to make this swap a sucess. i need to get the shifter and linkage with the trans right? what about driveshafts will i need a different one? i hope i can find one around for a decent price.
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 04-28-2012, 11:40 AM   #2
MusicMan70
MusicMan70's Avatar
Re: 3 speed to 4 speed od switch few ?ss
The main thing is to get a complete unit; shifter, rods and transmission. Correct bell housing if you need it.
Here are two articles and one link to a tranny without the shifter....
http://www.classicjunkyard.com/new_process_a833.htm
http://www.customclassictrucks.com/t...n/viewall.html
http://raleigh.craigslist.org/pts/2906324833.html
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 04-28-2012, 04:08 PM   #3
wlf89
wlf89's Avatar
what about driveshaft lenghts will the one i have now still work or have to get a different one?
69 lwb fleetside
67 swb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
Old 04-28-2012, 05:57 PM   #4
MusicMan70
MusicMan70's Avatar
I believe the OD my6 is the same length as a Turbo 350; short 6" version. If that's what you are replacincing then it should bolt right up. Double check all this of course. I replaced an SM420 so it required a longer drive shaft and a different input shaft.
MusicMan70
1961 GMC Suburban
