Old 04-28-2012, 02:15 PM   #1
crazy longhorn
Fabricate till you "puke"
Draining the coolant from the block (ls)?
There appears to be core plugs ,1 over the starter, & 1 down front low on the front, driver side. I dont see any drain plugs ,or petcocks , like on the old gen I. The question is, do these come out fairly easy, or do they require some heat? crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 04-30-2012, 10:32 PM   #2
crazy longhorn
Re: Draining the coolant from the block (ls)?
Ok, nobody else knew......so I will tell you! The front lh side is an oil passage. The rh side above the starter, came out, no issues(other than pukin 1/2 of the coolant on the garage floor). The left hand side, was a brass plug....I could not get that one to move! I will turn it upside down, as reccomended by the guys at Carshop inc in Moline, Il, to drain.. The gen I cast truck bell does fit, around that gen III starter.....with a little work on the inside of the bell(die grinder, with a whizz wheel) The gen I cast bell fits right over that gen III starter. Mods, you can move this if you feel the need, but I am not confused about where I posted crazyL
