Old 04-28-2012, 03:57 PM   #1
harrydunn
harrydunn's Avatar
Front Shocks
The '72 is coming out of hibernation. I slapped on some new rear shocks this morning and the ride is so much better. I need to replace the front shocks as well sometime. They look like they may be a little more difficult to get to as the nut is on the inside of the frame channel. I noticed some brake lines actually touching the nut on the passenger side as well. I'm just wondering if they are tricky to replace. I have not started it yet, so maybe it's not too bad.
Thanks.
Rear shocks from this morning:
1972 GMC 2500 Custom, 96K miles, Purchased New By My Grandparents
2016 Toyota Tundra TRD Off-Road SR5
1993/2003/2005 Toyota Land Cruisers
2004 Corvette Z06 / 2000 Covette Coupe
2006 Ducati Multistrada
2014 BMW X3 XDrive35i M Sport
harrydunn is offline   Reply With Quote
Old 04-28-2012, 08:09 PM   #2
kcsa75
kcsa75's Avatar
Re: Front Shocks
Piece of cake. Including taking the tire off it shouldn't be more than 10-15 minutes per side. It took me longer to replace the rear shocks.
Good luck.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 04-28-2012, 08:19 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: Front Shocks
I made some shock extenders for the front out of S/S.The hardest part was drilling the frame.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-30-2012, 10:14 PM   #4
twouvakind
twouvakind's Avatar
Re: Front Shocks
I didn't even take my wheels off. Not a bad job, just be sure to use the new supplied hardware with the shocks as it is captivating type(no lock washers)at least it is this type with Monroe.
twouvakind is offline   Reply With Quote
Old 04-30-2012, 10:35 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Front Shocks
Since I have rear leaf springs... even the rear shocks are EZPZ to replace.
The fronts are a snap too.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-30-2012, 11:08 PM   #6
Kidd-7
Kidd-7's Avatar
Re: Front Shocks
Hopefully they will be a snap for you; I had to cut the top bolt out of mine all it did was spin....
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
