Old 04-28-2012, 08:12 PM   #1
72k5zl1
72k5zl1's Avatar
wtb 6 cly. tach head
anybody have one? have extra v8 heads or cash. thanks, glen
72k5zl1 is offline   Reply With Quote
Old 04-28-2012, 08:39 PM   #2
bluek5
bluek5's Avatar
Re: wtb 6 cly. tach head
Hi, Question for you would a 6 cylinder tach read higher if installed on a 8 cylinder? The reason I ask is that my tach reads higher than the actual rpm. Are the tachometers marked 6 or 8 cyl? Thanks, Paul
bluek5 is offline   Reply With Quote
Old 04-28-2012, 08:43 PM   #3
72k5zl1
72k5zl1's Avatar
maybe? should be marked on back 8 cyl or 6 cyl. i have an 8 if you have a 6.
Old 04-28-2012, 08:49 PM   #4
bluek5
bluek5's Avatar
I will have to pull my instrument cluster and see I will let you know. Unless you find one before I can get back to you.
Old 04-28-2012, 08:50 PM   #5
72k5zl1
72k5zl1's Avatar
check it out and let me know. thanks.
Old 04-28-2012, 09:08 PM   #6
bluek5
bluek5's Avatar
I pulled it out and it's marked 8 cyl, sorry now I know. Good luck on your search. Paul
Old 04-28-2012, 09:30 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
A 6 cylinder tach should read about 30% higher than actual rpm on a v8.
The ink stamp should say either 6CYL or 8CYL. and if you can read it, the part numbers are.. 6CYL #6468321 ... 8CYL #6468228
There is a small screw on the back of the tach with a piece of tape covering it up. Just adjust it using another tach for reference, (both hooked up to the same engine).
Sorry about the hijack, Glen...
LockDoc
Leon
Old 04-28-2012, 10:32 PM   #8
leddzepp
Moderator
leddzepp's Avatar
I have an OEM 6 cylinder tach that I will be posting for sale here on the board late tonight when I get home. It will need to be restored. I will post you a link to the ad when I list it.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-29-2012, 03:25 AM   #9
leddzepp
Moderator
leddzepp's Avatar
Glen- Here are some pics. It needs to be restored. There are no burn marks on the circuit board, however I have not tested it. It is stamped 6 CYL on the back, it is faded and won't show up in the pic. It is easily seen when you are holding it in your hand. $100 Shipped. 6 cylinder tachs are pretty rare to come by, so if you have a nicer V8 tach, and can adjust it as Leon described above, I would go that route.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-29-2012, 08:48 AM   #10
72k5zl1
72k5zl1's Avatar
pm me before you post it. thanks. glen
Old 04-29-2012, 09:02 AM   #11
lolife99
67-72 parts collector,…
lolife99's Avatar
I think locdoc meant your could adjust out the minor inaccuracies in the tach with the adjustment screws.
You would still need a 6-cylinder tach for an I-6 engine.
Member 70shortfleet sells a "tach face" decal that take the tarnished look out of your old worn tach.
http://67-72chevytrucks.com/vboard/s...ight=tach+face
(my opinion,... $100 is a super deal, for the 6-cylinder tachs)
Keith
Convert to disc brakes.
Old 04-29-2012, 09:38 AM   #12
72k5zl1
72k5zl1's Avatar
i think so too. i am going to dig out some of my 8cyl tachs later and check it out.
Old 04-30-2012, 02:56 AM   #13
leddzepp
Moderator
leddzepp's Avatar
Glen, you have first call on it since I posted here in your thread. I priced it based on what I have seen V8 tach heads in the same condition sell for. If I had obtained it from a running truck and it was not so weathered I would price it much higher. I figure since it is for a 6 it is worth restoring. Thanks.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
