04-28-2012, 10:37 PM | #1 |
Tilt Column extravaganza!
5 tilt columns for sale : 2 vans, 2 motor homes and 1 truck. Add $25 each for shipping. Steering wheels will be removed for shipping.
Truck column - Needs a some work. It's a little loose (inner bolts need tightened) and shifter pin hole has some wear. Good wiring. $175 Motor homes - Same shaft length as truck. The linkage arm has a factory bend in it, but can be used as is. They are REALLY nice and tight and came off very low mile vehicles. Notice one has adapter for cruise and intermittent wipers (this can be removed) $225 each. Vans - 1 is in good condition - $150 ; the other one has wear in the shifter pin area and needs lever - $100 Please reply to thread.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
04-28-2012, 10:39 PM | #2 |
Re: Tilt Column extravaganza!
truck and vans:
04-28-2012, 10:39 PM | #3 |
in on the truck tilt pending better pics.
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
04-28-2012, 10:40 PM | #4 |
motor homes:
04-29-2012, 11:41 AM | #5 |
Leave some for the rest of us Duane! LOL
04-29-2012, 12:09 PM | #6 |
Still Learning
Please put me in line for the truck column. thanks
04-30-2012, 12:32 AM | #7 |
I'll take the motor home w/out the crusie/intermittent switch if available.
04-30-2012, 09:01 AM | #8 |
Heavymetal has backed out so all columns are available. DSALRAM - What else do you need pictures of on the truck column? Mcbassin - your next on the truck.
thecatseye - the motor home column is yours. Sending PM
04-30-2012, 02:38 PM | #9 |
Is the column repairable with whats there or are new parts needed?
04-30-2012, 02:59 PM | #10 |
PM sent. Thanks Joshua!
05-02-2012, 08:44 AM | #11 |
One motor home SOLD to thecatseye.
DSALRAM - The bolts can be accessed and tightened, just takes a little time. As for the shifter pin hole, I've heard of people filling with JB Weld and smoothing out. It is functional now, there's just some play in the shift lever. Besides that, just needs cleaned and repainted. Could use new levers (available aftermarket). JQ
05-02-2012, 06:57 PM | #12 |
Please put me in line for the truck tilt... Thanks..
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
05-02-2012, 07:53 PM | #13 | |
05-02-2012, 08:23 PM | #14 |
mcbassin - You are up for the truck tilt. LMK
JQ
05-02-2012, 10:14 PM | #15 |
Still Learning
JQ,
Which one of the above picture(s) are of the truck tilt? I know you said it needed some bolts inside tightened up, that's no biggy, what about the hole that is wore out? which picture is it? Pretty sure I can fix that too. Just want to be clear on which one is the truck tilt. What other new parts will I need to make this ready to install? thanks |
05-02-2012, 11:34 PM | #16 |
Look at the 2nd post with "truck and vans" as a heading. The truck column is pictured in the first 2 pictures, the second being the shifter pin hole. This column was pulled from a running 72 Cheyenne. Again, the main thing it needs is just cosmetic stuff - new levers, fresh paint. It has good wiring, bearings seem OK. I think the cancelling cam may have a crack where the signal lever attaches.
Joshua
05-03-2012, 07:33 AM | #17 |
JQ-72: Put me in line on truck tilt. I will take it at 175.00 shipped. Don
05-03-2012, 08:12 AM | #18 | |
Still Learning
PM payment instructions. thanks, Mike |
05-03-2012, 10:53 AM | #19 |
Still Learning
Payment sent thanks Josh.
Posted via Mobile Device |
05-04-2012, 08:20 AM | #20 |
TTT - still some available.
05-21-2012, 08:56 PM | #21 |
what do you have available?
Scott Daily Driver:2010 Z71 Ext Cab Project:1972 C10 SWB |
05-21-2012, 09:27 PM | #22 |
I'm down to the van tilts.
JQ
05-21-2012, 10:13 PM | #23 |
VA72C10
ttt
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 05-24-2012 at 01:35 AM. |
05-22-2012, 08:32 AM | #24 |
Van tilt is good and tight - just needs cosmetics. New paint and possibly new levers for high point show, scouring pad for driver! I'll PM payment info. Thanks.
Joshua
05-24-2012, 01:35 AM | #25 |
VA72C10
ttt for you
Looking for a 67-72 swb or blazer project in or around VA. |
