Old 04-29-2012, 01:08 AM   #1
landy
Dash Lighting Questions
Did the heating/AC controls have lighting? I have two bulb sockets hanging free that I think may have been for illuminating these controls. If so, where do they go?
The in-dash brake warning light doesn't come on when the ignition switch is turned on. The bulb is good, so maybe the switch is bad? I'm hoping I don't have to replace the whole entire porportioning valve?
When the parking brake is applied, should the in-dash brake light come on? I don't see a switch on the parking brake assembly, so I'm guessing that it doesn't light up when the parking brake pedal is depressed.
Thanks!
landy is offline   Reply With Quote
Old 04-29-2012, 09:11 AM   #2
jaros44sr
jaros44sr's Avatar
Re: Dash Lighting Questions
The brake light should only come on if you have a fluid problem with your brake system, it doesnt come on if your parking brake is applied
Should be a round hole in the back of your heater control, i dont have air, so i dont know if there are two holes for an a/c system, could be a radio light for the second bulb
Not sure if the brake warning light will come on with the ignition switch, havent gotten that far yet
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 04-29-2012, 11:21 AM   #3
landy
Thanks for the info. I can't see where the bulbs fit into the heater and A/C controls (mine has A/C). I guess I'll just have to fumble around until I find them.
The owner's manual indicates that when the ignition is first switched on, the brake light should light up to show that the bulb is working. Mine doesn't, but the bulb and socket are good. I tried them elsewhere and they worked. I guess it must be the switch??
Old 04-30-2012, 12:45 AM   #4
old man jimmy
your brake warning light should come on when you turn your key just before it reaches the start position for bulb check purposes.
old man jimmy is offline   Reply With Quote
Old 05-01-2012, 12:47 AM   #5
bigeasycigars
bigeasycigars's Avatar
Thanks!
Do they look like this? If so the push into the right and left end of the control unit. There will be holes on each side. Note that they have to be inserted to work as these are single lead sockets. The lamp used is a #1893 which according to my manual has an output of 2 candlepower. You might wish to use a #1816 which is 1/3 brighter with a candlepower output of 3.
'71 K/5 CST Work in progress...In Sicily, women are more dangerous than shotguns.
bigeasycigars is offline   Reply With Quote
Old 05-02-2012, 02:06 PM   #6
landy
Those are the ones. I found the holes were they plug into. Thanks!
