HELP...Please post some pictures your brake lines!!!
Hey guys, there are alot of things I can do but one experience I have not had is brake lines.
![]() Join Date: Oct 2009
Re: HELP...Please post some pictures your brake lines!!!
here's a pic of mine (before/after) from the mc to the frame rail anyway... Granted you'd have a diff mc and a booster probabaly, along with a prop valve, but, this is home made at the very least.
bump
I used straight 3/16 stainless lines and used JIC/AN style 37 degrees fittings. As far as Im concerned, other than in a all original restoration the 37 degree set up is the way to. Only needs a single flare, doesn't leak and can be loosened and re-tightened many many times w/o losing it ability to seal. Also gives you alot of options with things like passing through crossmembers. Heres a few pics of my truck.
oops, heres the pics.
#6 | |
![]() I must ask...where did you purchase the stainless steel lines and the bulkhead fittings? |
![]() Join Date: Sep 2005
www.inlinetube.com sells compelete kits prebent with the proper fittings on them for line 155 dollars
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Ss
1969 Chevy c20(Miss Hackjob) |
Got the lines from mcmastercarr.com and the fittings from anplumbing.com. Borrowed the 37 degree flaring tool from a friend, brand name was rigid.
duh, damn I get all kinds of stuff from McMaster Carr and didnt realize they had the tubing. They are an awesome souce of fasteners
#11 | |
