Wiper pulse module
Does anyone know where this is located on an 82 truck? I cant seem to find it and its not part of the wiper motor.
Re: Wiper pulse module
'82 has the wiper switch on the dash, so I'd check behind the switch. Maybe trace the wires if it's not right there. On the 84+ trucks I think it's at the base of the steering column.
Steve Member of the Foot Pedal Club '83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL, Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws, 350 HP 350 crate engine from Jegs, Turbo 400 ![]() |
On my 79 it was built right into the switch itself
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205 1971 GMC 3/4 Ton 4X4 |
Chevy Enthusiast
It should be on the bottom of the column behind the removable panel like this:
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
an 82 should still be behind the dash mounted switch.
#6 | |
In the Forgotten far North.
![]() Join Date: Jul 2007
'78-'83 they changed out the dash mounted switch with one that had a sliding(Off,delay,low,high) switch that also rotated for the delay timer control. The actual control module for it simply mounted in between the harness and the switch itself. the switch front view..... Back view.... The control module.... Both of them together.....
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
Chevy Enthusiast
Yep ^those guys are right, total brain fart. I knew that
Alright great thanks for the info.
GM Addicted
I have one out of a 77 single cab dually. Looks way different switch had a long harness running near the pedal will post a picture tomorrow, i need help seeing if it works before I install it
![]() ![]() 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
Yeah '77 was the first year for intermittent wipers and their design was a one year only thing from what I've learned/heard from numerous sources. The ones I showed above are a direct plug and play for the '78-'83 models
Is this plug and play module still available for intermitent wiper. I have just regular wipers on my 76 and would love plug and play this module into it.
Possibly. I'll have to research it when I get back to work next week.
#13 |
![]() Join Date: Dec 2011
On an 85, would it be under the steering wheel behind the cover correct. Also, would the switch be the culprit if my intermittent/pulse works at times and at times it don't? I replaced the wiper motor but the pulse is still the same. Thanks.
Posted via Mobile Device |
#14 | |
Moderator
![]() Join Date: Oct 2008
The 77 setup might work but they're scarcer than hens teeth. ![]()
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
