Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
View Poll Results: Dual plane or Single plane
Square port single plane 2 10.53%
Square port dual plane 1 5.26%
Oval port single plane 1 5.26%
Oval port dual plane 6 31.58%
Dual plane SBC 6 31.58%
Single plane SBC 3 15.79%
Voters: 19. You may not vote on this poll
Old 04-29-2012, 09:02 PM   #1
Blue Rat
Single plane or dual plane.
I know all the stuff that has to be figured in while trying to decide what intake to run. Just looking for a simple answer. What do you use?
Blue Rat is offline   Reply With Quote
Old 04-29-2012, 09:09 PM   #2
trevrolet65
Re: Single plane or dual plane.
Square port single plane for square port heads and watch the gas guage drop, lol.
trevrolet65 is offline   Reply With Quote
Old 04-30-2012, 12:09 AM   #3
dbmx66
what engine is would this be going on?
i run a fully ported brodix single plane
dbmx66 is offline   Reply With Quote
Old 04-30-2012, 03:42 AM   #4
BigDan3131
BigDan3131's Avatar
Your poll is like asking, why is the sky blue? Just fill in the basics like intended rpm range and used percentage. like 90% street to 10% strip...I have a small single plane on my motor now but will be upgrading to that composite one later this year.
BigDan3131 is offline   Reply With Quote
Old 04-30-2012, 06:59 AM   #5
Blue Rat
I understand that. But, it is answering my question. If I can get enough votes. I will explain myself after the results are posted.
Thanks for voting.
Old 04-30-2012, 07:12 AM   #6
shawnt
shawnt's Avatar
It makes no sense to vote on something without even knowing a combination.
They both have their place on a given combo so there is no way to vote now without knowing.......
Shawn
85 SWB
7.39 @ 93
Best so far with 0 tuning
Lesson in life: Never fry bacon naked!
shawnt is offline   Reply With Quote
Old 04-30-2012, 08:41 AM   #7
vin63
It's Better With Nitro
vin63's Avatar
X2...that's like asking what kind of ammunition do you use in your Colt firearm, .45 acp or a 5.56 x 45 mm? Each has a specific application.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-30-2012, 04:16 PM   #8
Blue Rat
This is not about my combo. It is about what intake you are running on your pickup. Other words what you feel works best with your combo an your pickup.
Other words if there are more votes for single plane that tells me that most trucks run good with a single plane even though there are still some what heavy. Since the single plane runs in the area of 3000 an over for the most part. If there are more dual planes. Then it's the other way.
Old 04-30-2012, 05:17 PM   #9
nomrlz
nomrlz's Avatar
i hate dual plane trips. nonstop flights only way to go to minimize chance of loosing my checked bag
66 LWB/BBW work in progress
68 Camaro SS bigger work in progress
95 Roadmaster Wagon 12.36 @ 107.74
99 Hayabusa 8.72 @ 162
00 Hayabusa 9.33 @ 153
nomrlz is offline   Reply With Quote
Old 04-30-2012, 06:04 PM   #10
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
cant answer this w/o knowing application (say a light sports car or dune buggy vs old bog old heavy cadillac or SUV.... and if its a BBC, SBC, LSx, BBF, SBF, Hemi,
you get the point.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-30-2012, 06:29 PM   #11
Blue Rat
you get the point.
Do you use a dual plane or single plane in your truck? That is the question.
Old 04-30-2012, 08:38 PM   #12
69GMC910
MOTORHEAD!
69GMC910's Avatar
Dual plane all the way!!!!
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-30-2012, 08:54 PM   #13
shawnt
shawnt's Avatar
It dont matter about the damn weight. Its about the.engine. You dont throw a single plane on a motor that peaks at 5000 and you dont put a dual on a motor that peaks at 8500. Combo combo combo.
This thread is just pointless to me..
Shawn
85 SWB
7.39 @ 93
Old 04-30-2012, 08:57 PM   #14
trevrolet65
In that case I'm running peanut heads. 882's on the mouse, both dual plane
Old 04-30-2012, 09:02 PM   #15
68GMCCustom
I USED a dual plane....now its an efi truck intake.
OK...........its REAL simple if you want to look at it that way. If doing much of anything except racing you want the dual plane. the single plane is worse at making power at lower rpm levels off idle to 2500-3500rpm...where a street car/truck lives. that same rpm range is where a single plane just starts to make power on its way to 6000, 7000 rpm, or more.
street or street strip use...............dual plane.
mean street/mostly strip/racing use..........single plane.
Kurt -
Old 04-30-2012, 09:38 PM   #16
vin63
vin63's Avatar
I know all the stuff that has to be figured in while trying to decide what intake to run...
This is not about my combo...
...it sure sounds like it is...
Old 05-01-2012, 04:13 PM   #17
Blue Rat
The first quote was for the responses I knew I would get.
The second quote was asking what intake do you find that work the best on your individual truck More curisoty than anything. That is why I included both SBC an BBC in the poll. If you try not to read to much into it it is easier to understand.
Old 05-01-2012, 06:26 PM   #18
Marv D
Registered Truck Offender
Marv D's Avatar
Umm lets see,, isn't a tunnelram with dual 4bbls a "dual single plane". LOL. Run one of those on the 66 and the only one of these 3 that is a race vehicle
a single plane GMPP Vortec TBI intake on the 383 TBI motor in the 94 4x4
and a single plane on the 327 MPFI motor in the El Camino
(note,, EFI is single plane happy)
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 05-03-2012, 10:42 PM   #19
BossHogg69
motor exploder
BossHogg69's Avatar
Dual plane (RPM Air Gap-port matched), 1" open spacer & Edelbrock 'Roval' ports on a BBC.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 05-04-2012, 12:25 AM   #20
Super73
Super73's Avatar
4150 single plain on the old 347 and same thing on the newer 418. Sure wish it had a dominator flange.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-04-2012, 12:53 AM   #21
redsled87
redsled87's Avatar
Oval Port Single plane "Old School" Torker 2-O. Gasket matched and 1" 4 hole Moroso spacer for now. I want a 004150 2" Wilson spacer though.
1987 R10 Pump Gas 496/TH375
Best 1/4 pass to date
60' 1.49
1/4 10.93
MPH 120
redsled87 is offline   Reply With Quote
Old 05-04-2012, 02:23 AM   #22
RatPwrd72
RatPwrd72's Avatar
Brodix HVH single plane rec. port with a little cleanup on the red truck.
The 468 in the '72 has worked over 781 ovals with an out of the box Air Gap.
1972 Chevy Cheyenne Super- Pump gas 496,TH-400, TCI Stall, 3.73's,Ochre & White two-tone w/Olive
Interior
1967 Chevy Short Step Drag Truck-Iron Headed 468 Making Memories
My momma took me off the bottle years ago.....
RatPwrd72 is offline   Reply With Quote
