Old and crusty
![]() Join Date: Jan 2009
Radiator/grill support panel question.
Are the radiator mounts supposed to be flat or do they have a slight bow to them? I have three of these and they all seem to be slightly bowed or bent. If they are supposed to be dead flat I need to straighten or this will affect how the fenders, both inner and outer mount up. Right? Thanks for your input.
Dean Last edited by dean jendro; 04-30-2012 at 10:01 AM. Reason: part description chnage |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Radiator mounting frame question.
If you are talking about the crossmember that the radiator sits on, yes it is supposed to be straight. So many of they are bent because most people seem to think that is a good place to hook a chain or tow strap when the truck needs help.
Old and crusty
Re: Radiator/grill support panel question.
I guess the correct part name would be radiator/grill support panel.
Old and crusty
Anyone know?
The radiator support is on the left and it is flat. The grill support is on the right and it has a slight bow to the front of the panel.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
