Mufflers/heat/wood bed
With the mufflers within several inches of the wood bed, is it recommended to have a heat shield between the mufflers and the wood?
Re: Mufflers/heat/wood bed
Yes. Called a tailpipe heat shield. Can be fabricated easily or bought for under $10 through most suppliers.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
Enjoy your truck
I don't have any shielding between my mufflers and the bed floor and I have never experienced any concerns. It's been that way for 15 years.
Greg
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
Depends how close the exhaust is run. If its close, I have seen the finish's crack from the heat. I purchased a heat shield for my bed, but I haven't installed as the exhaust is nowhere near the bed. I held onto it for when I do the V8 conversion. Ill have to have new exhaust run and might need it then.
wasn't the shield for the tail pipe when it went over the rear axle?
1961 chevy K10 my build is------------61K10 build |
Yes, I read post one wrong. The heat shield could also be used for mufflers too. Any heat source close to the wood would require one.
VA72C10
![]() Join Date: Mar 2008
that may be the case but I've also seen wood floors of panel trucks catch fire from hot exhaust...not worth the risk and as mentioned...at the very least it could crack the finish causing the wood to wear/rot prematurely...
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#8 | |
![]() Join Date: Feb 2001
![]() But I am glad that you have never had any issues. ![]()
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Better safe than sorry ...Anyone that has had problems,do you know how close is safe ?
usually if you can fit your hand between it you're good. you can always cerimic coat or wrap it with header wrap in that area.
96 s10 static drop smooth and blue 99 silverado nothing stock layed out on 24s 65 c10 bagged patina driver http://www.myrideisme.com/Garage/az480 half-assed build thread http://67-72chevytrucks.com/vboard/s...=1#post5206828 |
