Old 04-30-2012, 03:07 AM   #1
MikeS.
MikeS.'s Avatar
87 454ci motor
I'm looking at buying a Frankentruck that has a 1987 454ci motor out of a 'Burb, at 94k miles on the motor. Some ?s;
How reliable are these motors? 2 or 4 bbl carb? Did they come with electronic ignition or point & coil? What else do I need to know?
The motor is mated to a Turbo350 tranny on a 4x4 truck.
Thanks y'all!
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 04-30-2012, 03:44 AM   #2
Number21
Number21's Avatar
Re: 87 454ci motor
The 87 454 was a TBI motor with electronic ignition. That doesn't mean your truck doesn't have a carb, usually a 454 has a 4 barrel. I don't think you're supposed to mate a 454 to a TH350 though, too much power.
'73 K20 Cheyenne Super Camper Special 350/TH350/NP205 sittin' on 33's.
You can set my truck on fire and roll it down a hill,
and I still wouldn't trade it for a Coupe de Ville.
Number21 is offline   Reply With Quote
Old 04-30-2012, 04:45 AM   #3
MikeS.
MikeS.'s Avatar
Re: 87 454ci motor
It's definetely a Frankentruck, I just double checked, says it has a turbo350. I'll have to check some more on that issue. Thanks!
Past Master
Old 04-30-2012, 12:01 PM   #4
BigBlocksRule
Re: 87 454ci motor
It is a Mark IV engine, 2-piece rear main seal. Should have peanut port heads which should be the best for towing and mileage. If the TH350 is built decent, it'll handle it. There are tons of big power engines with TH350's at race tracks every weekend.
Check the tranny fluid, check it for a burnt smell that could signal overheating/overloading.
BigBlocksRule is offline   Reply With Quote
Old 04-30-2012, 06:35 PM   #5
MikeS.
MikeS.'s Avatar
Re: 87 454ci motor
Thanks!
Past Master
