Old 04-30-2012, 12:50 PM   #1
kevinc
kevinc's Avatar
Fan Removal?
Starting to remove all external parts to a 2002 5.3L to prep for paint. I'm finished except for removing the fan clutch from the waterpump. How do you remove it?
Thank you,
Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 04-30-2012, 02:26 PM   #2
Kim57
Kim57's Avatar
Re: Fan Removal?
Takes a special tool. It's a fan clutch wrench.
Be sure and get the tool that holds the pulley that the belt rides on also.
There are two small holes in the front of it that the tool fits in to hold it.
I borrowed one from Auto Zone to get mine off.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-30-2012, 10:35 PM   #3
awhite4557
awhite4557's Avatar
Re: Fan Removal?
I used an oil filter wrench with a rubber strap and a larg crescent. Hold the filter wrench tight on the water pump pulley and hit the crescent with a rubber mallet.
1950 Chevy 3100 Ramp Bed 1-ton
http://67-72chevytrucks.com/vboard/s...d.php?t=749386
1965 Chevy Step Side
1971 Chevy Short Wide Bed
http://67-72chevytrucks.com/vboard/s...d.php?t=277191
1971 Chevy C-30 1-ton
1971 Chevy Chevelle
1972 Chevrolet C-30 1 ton
2005 Dodge Ram 2500 5.9 Cummins
2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins
2020 Jeep Wrangler Unlimited Rubicon
awhite4557 is offline   Reply With Quote
Old 04-30-2012, 11:37 PM   #4
ls1nova71
ls1nova71's Avatar
Re: Fan Removal?
If you get one that just won't budge, an air chisle works great!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
