window cranks 1971
Was there a set position that gm installed the window cranks on trucks. Like when the window was up was the knob at 12, 3, 6 or 9 o'clock position?
Fuzzy |
Junior Member
Re: window cranks 1971
I like to install them pointing away from the door hinge. 9 o'clock for driver side and 3 o'clock for passenger side. #1 It fills out the space on the door panel there. #2 The weight of the handle tends to keep the window up in the closed position. I read that somewhere a long time ago and it made sense to me.
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
![]() Join Date: Jul 2010
I wondered the same thing. I couldn't find the answer. So, I started looking at pictures of "original" trucks. Every one of them has the window crank and door handle pointing toward the front (when the window is closed). So, that is how I did mine.
Board Member #87725 My build thread... http://67-72chevytrucks.com/vboard/s...d.php?t=813848 |
Thanks for your suggestions stomper and omodified anyone else
Fuzzy |
I adjusted mine to the 7 o'clock position for one reason.... it was out of the way..
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
![]() Join Date: May 2010
As I recall mine were at about 1:30 on the driver's side and 10:30 on the passenger's side when the truck was new. About 45 degrees up and to the front. That's where I've kept them.
Jim |
anymore info on this subject
Fuzzy |
#8 | |
Frequent Flyer
I have the billet handles & cranks I elected to have them at the same angle as the door handles when the window is down for the fact that my windows are down at car shows & cruise night. |
I'm gonna try the 3:00 position on my passenger side crank as it always slowy opens it up a bit. Thanks for the info gotta love this site!!!!!!
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
I do this with all my crank window vehicles. Close the window and set the crank so it does not bother my knee, then roll the window all the way down and see if the window crank will be into my knee again......then adjust accordingly.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride! Where patience fails, force prevails Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle." |
I knew somebody that got their leg screwed up in a accident by the handle
It was facing rear ward the round part broke off when he hit it and the shaft portion really got him good in the leg. since then I allways try to face the handle forward open or close cause that was ugly
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
