05-10-2003, 05:26 PM | #1 |
Need carpet cutting tips
I am going to put in my carpet. I don't plan on gluing it down. I was wondering how to cut the hole for the dimmer switch, the gas pedal knobs, and for where the seat bolts into the cab. Thanks
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-10-2003, 05:36 PM | #2 |
Its Magically Delicious
a sharp razor im guessing will work fine ....might take a lighter and melt the ends slightly to prevent fraying
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
05-10-2003, 05:37 PM | #3 |
not sure, but maybe some one on the pant and bady board would know if not here!
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ "Why couldn't you have just put the bunny back in the box?" ~ |
05-10-2003, 05:49 PM | #4 |
71 longbed is pretty much on track sharp knife and a lighter should do it just fine measure twice cut once
05-10-2003, 05:53 PM | #5 |
make sure you cut it big if your not experienced at cutting carpet, alittle trick for cutting the seat bolts, is put them in before you through the carpet down and you will beable to feel them through the carpet, then just cut the carpet on the bolt head cris cross with a razer blade, same with the dimmer switch, just do lots of measuring, and trimming till you get it to lay where you want it, my 2 bits
05-10-2003, 07:20 PM | #6 |
ran out of money
i have done it the same way Casey has. and i have done about 5 carpet sets..... not all in trucks like ours, but none of them came out wrong..... just take your time. i also found out that a spray adheasive made by 3M works great for the extra hold around the trans hump and everything. best of luck and take you time.
Modify everything, leave nothing alone!~ |
