NP205 and automatic trans question
Hello, I have a 72 1/2 ton 4x4 with a th350 trans and a np205 transfer case. I want to change the trans to a th400. Do I only need the 400 adapter to connect to the 205? Is the 400 longer than the 350. Any other issues. Thanks
Re: NP205 and automatic trans question
Not 100%, I believe the 400 is longer and the spline count is different. (27vs32?)
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ![]() I'm kinda like duct tape- no real purpose, but handy to have around. |
I built it
the th400 is quite a bit longer then a th350. and the output is bigger on the th400 so you'd need the matching 205 and adapter. or a divorced setup.. also between the th400 there are i think 2 diffrent length outputs so make sure you have the right adapter for the trans
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
