Lowering blocks
Installed 1 1/2" lowering blocks on the butt end of my 72 LWB.
It now sits level and looks (IMHO) pretty cool. I have 2 235/60/15 tires which are shorter than what is on there now (I forget). What if I got a couple more and put those on? Or maybe something either narrower in the front or wider in the back? They'd have to mount on my van take-off ralleys, which I think are 7" wide. Thanks |
225/60 or 215/60 on that size rim would look sweet
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction). Progress on truck so far (follow link): http://67-72chevytrucks.com/vboard/s...ad.php?t=51051 and stage 2 http://67-72chevytrucks.com/vboard/s...ad.php?t=58132 ~ ![]() ![]() |
Showing my ignorance here, but are the sizes you mention wider/narrower or taller/shorter than the 235/60s?
Thanks |
They would be shorter and a little narrower.
You can check out this site and play with the sizes. You can also see how far off your speedo will be. Tire Size Calculator
'68 GMC 1500 LWB Fleetside w/350 & 3 spd (for now) |
