Old 04-30-2012, 06:51 PM   #1
determined1
66 c10 questions?
i want to convert my 66 c10 over to a dually. anyone ever thought or seen it done. ive looked on here and have seen them with the bed all done up. not really in the direction im going. it has 73-87 5 0n 5 setup now so i was wondering if it would be the same for dually setups.(running i guess 8x6.5 )i guess my question is will this bolt up to a 66 frame?
determined1 is offline   Reply With Quote
Old 04-30-2012, 07:00 PM   #2
determined1
Re: 66 c10 questions?
just to clarify i know of one truck that is similar to what i want and its a black dropped dually im guessing 64-66 that was static dropped, anybody know what components he used?
Old 04-30-2012, 08:35 PM   #3
determined1
nobody?
Old 05-01-2012, 12:49 AM   #4
Captainfab
60-66 Nut
Most anything can be done if you have the skills, time and money to make it happen. To convert to a dually rear, you will need to change over to either a 10.5 FF 14 bolt or a Dana 70.....a Dana 60 would work also. Of course these will have the 8 x 6.5 wheel bolt pattern. Typically the '60-'66 dually's had leaf springs, but you could keep the trailing arms and panhard bar. Either way there will be cutting and welding involved.
Old 05-01-2012, 10:54 AM   #5
determined1
Thanks for the reply. I was just trying to figure out if it would be bolt on just like the 73-87 pattern. The only difference being your using c30 instead of c10. I figured the back would be the easiest since im losing the bed and putting a flat bed on it.
Old 05-01-2012, 01:02 PM   #6
determined1
i dont know if anyone has any info on this but something like this truck only with one of those knapheide flatbeds on it. anybody think this would be too much weight on those coils.
