Old 04-30-2012, 08:22 PM   #1
akc900
Wink New dash board
How hard is it to take out and install a new dashboard, I'm new at all of this rebuilding and wanting to do alot of it myself and learn as I go.
akc900 is offline   Reply With Quote
Old 04-30-2012, 09:00 PM   #2
mr48chev
mr48chev's Avatar
Re: New dash board
Those are spot welded in so you would have to drill the spot welds out to get the dash out of the truck.
I guess I had better add, are you putting a 56 dash back in the truck or changing to something else? If you are changing you can run a sawzall or cut wheel along and inch or so into the dash and cut the dash out that way and have something to fasten the new dash to but that doesn't work if you are putting a stock dash back in.
Old 04-30-2012, 09:04 PM   #3
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: New dash board
Are you going back with an original or something custom?
ChuckDriver is offline   Reply With Quote
Old 05-01-2012, 06:26 PM   #4
akc900
Re: New dash board
I will be going back with an original, I already have it.
Old 05-02-2012, 12:54 AM   #5
Dan in Pasadena
Dan in Pasadena's Avatar
Re: New dash board
What is SO wrong with the original that you feel you have to replace it rather than repair it?
Dan in Pasadena is offline   Reply With Quote
Old 05-02-2012, 09:34 AM   #6
G&R's57GMC
G&R's57GMC's Avatar
Re: New dash board
Old Dash ????
G&R's57GMC is offline   Reply With Quote
Old 05-02-2012, 11:35 AM   #7
mr48chev
mr48chev's Avatar
Re: New dash board
If one of the tri-5 guys has the 55/57 or 59 assembly manual They may be able to copy and post the page that shows were the spot welds are that hold the dash in. You will have to drill/cut each of those out so the old dash comes out.
This is a reprint that is sold on Ebay There is a lot of extra stuff in them but they do usually have diagrams and measurements for installing each panel and each chassis part on a stock truck. http://www.ebay.com/itm/1955-56-57-5...958014&vxp=mtr
dashboard swap out
